Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Charge Not Holding
The charge on the battery runs out fast or does not hold a charge at all.
Faulty Power Cord
Plug in the power cord to the laptop and the wall, if there is a light on the battery then the power cord is good. If the light is not on or if the laptop is not charging then the power cord is broken and the power cord needs to be replaced.
Faulty Battery
If your power cord is working properly, but the laptop will not stay on if you unplug the laptop from the power cord, then the battery is broken. You can replace the battery with help from this guide. Battery Replacement Guide
Not Cooling Properly
Device is staying hot or overheating and shutting down.
Faulty Fan
If your laptop is properly placed in a cool area but still overheating and shutting down, the fan inside your device is broken and needs to be replaced. For help replacing the fan use this guide. Fan Replacement Guide
Screen Non-Responsive
The screen will not turn on or turns on and goes out.
Not Charged
Check to make sure that the device plugged in or has a charged battery. If the battery is not charged or the laptop has a power source the screen will not stay on.
Screen Blackout
If you have confirmed the laptop is charged or has a power source and the screen is still black, the screen is broken and needs to be replaced. The following guide will instruct you on how to replace the screen replacement. Screen Replacement Guide
Clicking/Grinding sound from Hard drive
Clicking sounds coming from the laptop.
Motor Stops Working
When the hard drive motor stops working this causes the laptop to shut down. This is caused by broken components inside the hard drive that block the disk from proper function. The following guide will instruct you in the hard drive replacement. Hard Drive Replacement Guide
Touchpad Non responsive
The touchpad seems to be unresponsive or broken.
Faulty Touchpad
When you are moving your finger across the touchpad and the pointer on the screen isn't moving, this is caused by a broken and nonresponsive touchpad. The following guide will instruct you how to replace the touchpad.
1 Comment
I setup AMD videocard original driver and half setup the Screen goes black.
Kick out me from teamviewer.
IDK what’s the problem here?
Is it “ Screen Non-Responsive? ”
Bálint Gazdag - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 32
All Time: 3,153
