Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Does Not Power On
Device doesn't show signs of life, doesn't power on or show a sign that need battery.
Check battery
Make sure the battery works and if it doesn't work you need to replace the battery. If the battery does work check your charger or charging port.
Battery Connected Properly
Make sure your battery is connected properly to the motherboard, it could be disconnected from all the movement that happens to the laptop and all it needs is a simple plug in. If the battery shows any sign of swelling replace it.
RAM properly connected
Make sure the RAM is connected properly, sometimes the reason a computer doesn't power on is because the RAM isn't connected properly or the RAM doesn't work at all.
Screen Doesn't Work
The device turns on but doesn't display anything, replace your screen or check internally if anything is disconnected.
Screen Connected Correctly
Sometimes all it needs is a simple push. Check if the screen is a little pushed out, out of place or fully disconnected. Push it back in or reconnect the cables.
Display is Internally damaged
Screen has internal damage which leads it to look static, which is physical damaged like a strong hit to the screen. Replace the whole screen.
Keyboard Not Responding.
If you're typing keys and the keyboard isn't responding check if the keys are fully pressed in and if the keyboard is connected or in some instances, turned on.
Keyboard Misconnection
Check that keyboard is connected to the computer or check if there is any connection issues between keyboard and device.
Software Issue
Sometimes the software is not up to date with keyboard that will lead to a misconnection. Constantly check for updates if something is not working.
Physical Damage
Check for any spills, dust, wear and tare, stuck or lose keys that may be causing hardware issues, sometimes all it needs is a simples clean.
Rigoberto
336 Reputation
2 Guides authored
Gateway, Team 99-99, Gonzalez Spring 2024 Member of Gateway, Team 99-99, Gonzalez Spring 2024
GCC-GONZALEZ-S24S99G99
2 Members
36 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 36
All Time: 540
