Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
My game is not responding to any of my actions.
The console is frozen.
Do NOT try to turn the console off by pulling out the power adapter. This could cause serious damage.
The console needs to be restarted.
Press and hold the power button down for 15 seconds to shut the console down. After 15 seconds, press the power button to turn the console back on.
Try resetting the LeapTV.
Start with the console turned off, turn it on, as soon as it is turned on, press and hold the “Sync” button until a green ring flashes on the front of the console, follow the instructions that appear on the screen.
I want to add another player to the game.
More than one player is wanted or needed.
Second controller not active.
Please be aware that a second controller will not become active until you have entered a dual player game. First, navigate to the home page. On the controller, press the Home & Hint buttons together for 3 seconds until the light at the bottom turns blue. Next, press the Sync button on the console. After you press the Sync button on the console, the light on the bottom of the controller will turn magenta after a few seconds. After another few seconds, the magenta light will turn off and you will be connected.
The game is not working when I put it in the console.
For some reason, the console is not recognizing the game.
The contacts of the cartridge are dirty.
Clean off the gold contacts of the cartridge by using a pencil eraser and gently rubbing the eraser over the contacts. This removes dust and other particles that could be interfering with the cartridge being recognized by the console.
Make sure that your LeapTV has all of the necessary updates.
Ensure that all updates have been installed. Turn on your LeapTV on. Your console must be connected to the internet. Navigate to the Parent Settings page on the LeapTV. Type in your four-digit parent code (To skip this step enter: 196 <backspace>87). Choose Settings. Choose “System Info.” If it shows that you have 7.1.2.4011 or higher, no update is needed. If it shows that you have lower than .1.2.4011, an update is needed. If you are connected to the internet look for the “System Update Available” button. Choose this button, and wait for the update to download and install. If you are not connected to the internet choose the “Back” button and then the “Network” button. Connect to the internet. Go to the “System Info” screen. Update the firmware.
I need to reset my LeapTV back to the manufacturer’s settings.
When you need to completely reset the LeapTV.
To reset/clear the LeapTV the LeapTV should be turned off before starting. Turn the LeapTV ON by pressing the power button. Right after the LeapTV has turned on, push and hold the SYNC button until you see the green light ring on the front of the console blink. Follow the instructions on the screen to complete the reset.
Nathan
38 Reputation
0 Guides authored
IUPUI, Team 1-2, Baechle Fall 2016 Member of IUPUI, Team 1-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S1G2
4 Members
0 Guides authored
26 Comments
still does not work
Lea Duquette - Reply Share
its on a leap tv needs repaired screen what do i do
nsvc1234 - Reply Share
When I do this it says system needs repair and instructs me to hold sync button and then hold sync and power and the same time. When I do this the console turns off after a few seconds but contents are all still there, no reset.
Megz Carter - Reply Share
Hey game is doing the exact same thing! ..did you ever find a soulution? Or find out what the problem was?
Thanks
Kendra Shaw - Reply Share
Any luck finding a solution? Thanks
mhmoodhamooda - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 57
All Time: 18,580
