Phone won't turn on
No matter what you do, you can't get your phone to turn on.
Needs Proper Power Up Procedure
Before opening the device, make sure you firmly hold the PWR button for 5-10 seconds.
Drained/Bad Battery
Plug your phone into your charger. If it does not seem to connect automatically, gently, but firmly push the end of the charger into the charging port on the phone.
Have your phone provider check your charger to determine if it is the problem and not your battery.
If you have determined that your battery needs replacing, a 3.7 V 1000 mAh LG lithium-ion battery specific to this phone will need to be purchased. Refer to Battery guide to fix the problem.
Screen display is not working
Visibility in the screen is compromised
Screen All Black or All White
The usual home screen and display does not show up and instead the screen is all black or all white
Turn the phone off and then turn it back on. If this does not work, the connection between the phone's hardware and the screen may be compromised. To fix the problem, refer to guide to replace the Screen Assembly.
Screen Dark/Dimmed
First try to change the brightness settings of your phone. If this does not work the back-light has probably malfunctioned.
Getting error messages or phone running slowly
Needs Software Update
Ask your mobile provider if there are any software updates available for your phone. If there are, have the provider update the phone, or find the update online.
Corrupt Circuit Board
If the phone is not functioning correctly, or is functioning extremely slow, the problem may lie in the circuit board of the phone. Take the phone to your local vendor and have them diagnose the problem. Refer to the guide on replacing the phone's Circuit Board.
Camera does not work
The camera either does not take pictures or they appear fuzzy
Clean the lens with a non-abrasive cloth. If this does not work, then turn the phone off and turn it back on. Otherwise, take the phone to a local repair shop or distributor to fix the problem.
Hinge of phone is broken
The phone does not 'snap' open, or will not stay closed
When the phone is having difficulty staying open, staying closed, or not closing all the way, the problem is most likely a broken hinge. Make sure the hinge is clear of any obstructions and dust.
Keyboard is not responding
The screen looks normal, but the phone does not respond when buttons on the keyboard are pressed
Turn the phone off and then turn it back on. If this does not work, refer to the guide to replace the Keyboard.
Sound is fuzzy or non-existent
"Phone call sounds are fuzzy or silent"
Refer to the guide for replacing the Speakers
Signal weak or nonexistent
The phone will not process any signal and has trouble making calls or sending texts
The likely cause of this problem is a bad built in amplifier inside the phone.
Author
with
Meagan
1 Reputation
0 Guides authored
Clemson, Team 14-7, Benson Fall 2013 Member of Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 Members
96 Guides authored
2 Comments
Old lg mob. Makes calls but does not receive calls Advice please
John Tait - Reply Share
Old lg mob. Sends calls but does not receive calls Advice
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,484
