LG Rumor Touch won't turn on
You hold down the power button, and nothing happens.
Keyboard is unresponsive
The keyboard button pad may be dirty, disconnected or broken inside the phone. If this is the case, take the phone apart, clean the button pad and examine its connection to the logic board for breaks or extreme wear.
Battery is drained/defective
The battery may be worn out, causing it not to hold a charge. If this is the case, a replacement must be installed.
Logic board is defective
The logic board of the phone may be fried. If this is the case, a replacement must be installed.
LG Rumor Touch won't hold a charge
You charge your phone, and nearly immediately after you unplug the phone from the outlet, the phone turns off.
Charging cable is not fully plugged in
The charging cable may not be fully plugged into the LG Rumor Touch or into the wall outlet. Double-check to make sure the charging wire and plug are fully secured into both the LG Rumor Touch and the outlet.
Battery is drained/unresponsive
Charging cable is unresponsive
The charging cable may be broken or bent restricting the flow of electricity. If this is the case, a replacement charging cable must be ordered.
LG Rumor Touch Camera is not working
You try to take a picture and the picture is distorted.
Camera lens is cracked
The image is distorted when you try to take a picture. If this is the case you will need to replace the camera lens.
Camera lens is dirty
If the camera is completely dirty it will show a black screen. If it is semi-dirty it will show a distorted image. If either of these cases is present you must take apart the phone and clean the camera lens.
LG Rumor Touch does not produce sound
There is no sound when phone rings, plays music, or when alarm clock goes off
Speakers are broken
The speakers may be broken, if this is the case you need to take phone apart ,remove speaker, and have a new replacement.
Logic board is malfunctioning
The logic board may be worn out or unresponsive. Remove all parts leading to logic board and have replacement of board.
LG Rumor Touch Keyboard keys are not working
"The keys do not respond to being pressed, or the keys stick when pressed"
Keyboard pad is broken
The keyboard pad could be broken, if this happens you may need to disassemble the phone, and put in a new keyboard pad.
Logic board isn't working
If the logic board is unresponsive. Disassemble the device and put in a replacement.
Keyboard pad is dirty
In this case simply disassemble the phone and clean out the keyboard pad. If keyboard remains unresponsive consider replacement.
Author
with
Ivan Rojas
107 Reputation
1 Guide authored
Cal Poly, Team 17-2, Forte Winter 2014 Member of Cal Poly, Team 17-2, Forte Winter 2014
CPSU-FORTE-W14S17G2
5 Members
72 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 2,756
