Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone Will Not Power On
The phone does not show any response to power and will not power on.
Faulty Power Adapter
Ensure the power adapter is plugged in and the charge light is on. If the light is not on, and the adapter is plugged in, the adapter is faulty. Consider purchasing a replacement adapter.
Faulty Battery
Make sure the adapter is plugged into the phone and the charging light is illuminated. If the phone only powers up when the adapter is plugged in, regardless of charging time, then the battery is faulty. Replace the battery using this guide.
Keyboard isn’t responding
The keys on your keyboard won't respond and there is no response from plugging in the adapter.
Faulty Keypad
If the entire keypad/keyboard fails to respond, try replacing it with this guide.
Keys Are Stuck In Place
When the keys can't be pressed, there may be something that is blocking the key from being pressed down. To fix this, remove the key and make sure nothing is stuck below it. You may need to wipe off the area underneath. Once it is sufficiently clean, follow this guide to reinstall the keyboard into the phone.
Keyboard does not light up
If your keyboard does not light up but still responds to input then follow this guide to replace the keyboard.
Unexpected Restarts
Your phone will restart without prompting, and will not run the expected actions. It will also turn off as if the battery is dead.
Faulty Motherboard
If your phone randomly shuts down or restarts it is possible that the motherboard is faulty and needs to be replaced. An easy way to determine if your motherboard needs replacement is if your battery holds a charge, and looks to be in good shape. You can find a complete guide here on how to replace
Bad Battery
If the motherboard in your phone was recently replaced, it may be the battery that is causing the shutdowns and restarts. If the battery looks damaged it is a good idea to go ahead and replace it. If your battery does not hold a charge or does not charge at all, it is most likely the reason for the restarts and shutdowns.
Sending Error codes
The phone is displaying error codes on the following components, find out which part needs replacing to clear the code below.
Faulty camera
Your phone may be sending pop up error codes regarding the camera. It is possible that the camera lens or electronics may be malfunctioning. It will need to be replaced if this error code persists.
Bad screen
Your phone may not receive touch inputs or does not change when a screen change is prompted. Phone calls and texts will ring, but not show up on the screen. When the screen does display, it shows an error code regarding the screen malfunctioning.
Bad battery
A constant error code regarding the battery is present. The battery is low on power regardless of charge time and a low battery warning is present often.
Author
with
David Rasmussen
51 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 852
