Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Front Screen is Shattered
The front screen has been damaged (scratched or cracked).
If the phone's front screen is damaged you may need to [invalid guide link] to replace the screen.
Dim/Dark Screen
The screen appears dim, off colored, or dark.
Brightness Settings Are Too Low
If possible go into the phone settings and look at the display options. While in the display options, see if the phone’s brightness can be adjusted to a visible or desired setting. If adjusting the brightness on the phone did not work, check to see if the auto-brightness has been turned on. If so turn off.
Damaged/Malfunctioning Proximity Sensor
If altering the display settings of the phone was not possible or did not yield any results, the proximity sensor may be the issue. Go back to the display settings and turn the auto-brightness on. Locate the proximity sensor (a small circle in the left topmost corner in the phone) and place your hand over it for 15 seconds while the phone is on. If no change happened in the brightness in the screen the the proximity sensor may be damaged and you may need to [invalid guide link].
LCD Screen Is Cracked/Burnt Out
If your LCD or Digitizer screen appears black, cracked, or the color is distorted, then the phone’s LCD will need to be replaced. You will need to [invalid guide link]
Camera captures distorted or dark images
When using your phone to capture pictures, the images seem blurry, shadowed, or distorted.
Lens Is Cracked
If you have shattered or cracked the lens of your back camera, then you will need to [invalid guide link].
Camera Sensor is Displaced/Broken
If the phone does not have any visible cracks or scratches on the camera lens,there may be something wrong with the camera sensor. First, restart the phone. Once the phone is restarted go into the camera settings make sure that everything matches the factory default settings. If you are not in a well lit area make sure that the flash is on, then proceed with taking a picture. If the picture is still distorted or shadowed you will have to [invalid guide link].
LED is Disconnected/Damaged
If the flash is not working try going into the phone settings and check to see if the flash is turned on. Go ahead and turn it on if it was originally in the off state. Take a picture and if the flash still is not working, you may need to [invalid guide link].
Music audio is low, distorted, or off
Sound settings are too low
Your sound settings may be set to low or off. This may occur accidentally by pressing the buttons on the side that control volume. If this is the case then going into settings and raising the volume should solve the problem. If it doesn't it may be due to a damaged part.
Speaker Malfunction
If there is low/distorted sound coming from the speaker port, first check to ensure that the sound settings are on. If the sound is on and there is still low/distorted sound then the speaker may be disconnected or damaged. If it is then you would need to [invalid guide link].
Audio jack malfunction
If there are headphones at use first try using another set of headphones before coming to any conclusions. If there was no change in the audio then the audio-out jack may be damaged and you may need to [invalid guide link].
Home button will not work
If home button sticks when pressing it, try cleaning it using a small brush. If that does not work and the buttons do not respond, consider replacing the button sensor. Go to the [invalid guide link].
Phone won’t turn on
The phone remains off whenever I press and hold the power button
Battery may be missing or drained
Remove the back case and make sure the battery is in the phone and properly connected. If the is properly connected and the phone won’t turn on, charge the phone and then try turning on the phone. If that doesn't work then the battery most likely needs to be replaced.
Battery needs to be replaced
If the battery isn't charging or holding a charge then it needs to be replaced. You can find a replacement battery on online retailers like Amazon or eBay.
Paul
145 Reputation
4 Guides authored
USF Tampa, Team 8-1, Leahy Fall 2014 Member of USF Tampa, Team 8-1, Leahy Fall 2014
USFT-LEAHY-F14S8G1
4 Members
60 Guides authored
1 Comment
My sleep button works. But my volume and home button do not. Seems like a software issue because they can wake the phone just like the sleep/wake button. Any ideas what might be up
Joshua - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 3,974
