Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Replacement Warning
Before attempting to replace any of the parts to the device, to avoid damaging the device further(or beyond repair) restart or power off the device then turn it back on. This usually fixes most issues.
Black Screen
You can't get your screen to turn on or light up.
Dead Battery
Battery may be too low for the phone to operate. Try to connect your phone to a charger and wait for the phone to turn on. If your phone still does not turn on you may have a faulty charger. Make sure your charger is fully plugged into the wall and properly connected to your phone. If the problem proceeds you may want to try to connect to another charger.
Bad Display
The display screen may be too damaged to display an image. This may be the issue if the screen shows minimal light or remains completely black.
Battery won't keep charge
Damaged Charger/cord
Charger may be broken or not connected completely to the phone. First, make sure the charger is working properly and plugged into a working outlet. If the charger is working correctly, your battery may be damaged and require replacement.
Battery Damaged
Battery may be broken. Replace with a new battery by taking off the back of the phone, lifting the sides of the battery to take it out, and putting a new battery in. Once you have replaced the battery, try to power the phone on using the power button.
Bad Charging Port
After being certain the battery or charger is not the problem it is possible for the issue to be the charging port itself. If the device gets hot while charging or it takes much longer than usual to charge the battery then the port may be damaged and in need of a replacement.
Touch Screen Unresponsive
Device cannot recognize that the screen had been touched.
Dirty Screen
Check the screen itself to see if there is any residue on it. Grease, and sticky foods can attach themselves to the screen making it difficult for the device to read touch inputs. Try cleaning off the screen with a damp cloth to remove the residue.
Broken Screen
If the screen is cracked or damaged it can make it difficult for the device to read touch inputs. Follow this guide in replacing the touch screen on the device.
No Audio
Audio cannot be heard out of speaker/ headphones.
Volume
The device may have its volume lowered too low to be heard. Go to settings->Audio settings, and make sure the volume is on and turned all the way up.
Faulty Head Phone
The headphones you are using may be damaged. Try using another pair of headphones before attempting any repairs.
Blocked Head Phone Jack
Headphone jack may be blocked inside. Use a flashlight to look into the headphone jack. If you see any residue in the headphone jack, you may want to use a pin or needle to gently remove it.
Buttons not working
Buttons are stuck or require multiple, hard presses to work.
Home button not working
Home button may be dirty. Dirt may be built up around the home button keeping it from working properly. Clean the area around the home button and attempt to press it once more.
Volume buttons not working
Volume buttons may be dirty. Dirt may be built up around the volume button making them hard to press or unresponsive. Try to clean the area around the volume buttons and check to make sure they are not stuck.
Camera not working
Camera may not respond to the phone when the camera application is open
Camera lens is cracked
The lens may be cracked due to the phone being dropped on a hard surface. If the lens is cracked you will be able to know when you try to take a picture and there will be a line through the picture.
Author
with
Scott McGillowey
20 Reputation
0 Guides authored
4 Comments
Hello i have a LG optimus exceed 2 and it won't turn on. I try to turn it on but it will only say LG on it then the screen stays stuck on a gray screen. Anybody help me plz
Angel Villanueva - Reply Share
Same thing with mine
Nicole LeBlanc - Reply Share
phone shows battery when charging but doesn’t show enything else
C Speight - Reply Share
Mobile camera kaise theek karte dikhao
Saiprakash mhetre - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,770
