Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
G2 mini will not turn on
No matter what you try, your G2 mini will not turn on when you hit the power button.
Dead Battery
The battery on your LG G2 could be dead. Try plugging it in for at least 30 minutes, then try pressing the power button again. Make sure to use the original G2 mini charger and cable, not all chargers are created equal.
Bad Battery
The battery of your G2 mini may be bad. Batteries can wear over time to the point that they no longer hold a charge. They can also be damaged due to factors like exposure to moisture and heat. In this case you should replace the battery using the battery replacement guide.
Bad display
It is possible that your G2 could be powering on, but the LCD display is broken or the back-light is not functioning. Check for start-up chimes or vibrations when the device is booting. Try moving the volume rocker to test if sounds come from the speaker or if the vibrator goes off when the phone hits "vibrate" mode". If these actions work, your phone could have a bad display. Also try holding a flashlight up to the display and look very carefully. Try swiping on different sections of the screen. If you can see faint outlines of icons and text on the screen, then the LCD back light may not be functioning.
Slow Performance
When apps take a long time to load, transition animations stutter, or apps freeze and crash.
Corrupt Cache
The Android cache could be corrupt causing app freezes or sluggish performance. Take these steps to clear the cache partition:
  1. From the home screen tap Apps
  2. Tap Settings
  3. Tap General tab
  4. Tap Storage
  5. Tap Cached
  6. Tap OK
  7. The cached data will clear, this may take several seconds.
Faulty Application
A faulty app could be affecting the permanence of your device. Try checking for new app updates, uninstalling suspect apps or installing a resource manager to find apps that are using up data and CPU cycles.
Trouble Making Calls or Sending/Receiving Messages
When you cannot seem to make phone calls or send and receive text messages.
Lack of Service
You may not be within range of a cell tower. Check that your device has signal where you are.
Radio/Phone Bug
There could be a bug in the software that controls the phone's wireless radio. Restarting the phone usually fixes the issue. Also try checking for new software updates from the settings menu.
Temporary Network Issues
The issue could be a temporary network issue. Try changing location or waiting 24 hours. Otherwise call your service provider.
Airplane Mode
Make sure that the device is not in Airplane Mode.
The Touchscreen does not Respond
The display is on, but nothing happens when you touch it.
The screen could be dirty
Oil or water on the screen can cause it to malfunction. Clean it using a microfiber cloth.
The Digitizer is Broken
It is possible for the sensor that reads touch input to fail. In this case you will want to seek a replacement guide for the LG G2 mini digitizer.
You are not directly touching the screen
Interacting with the screen through gloves or other materials will not register finger touches. Take of any materials that could be covering your fingers.
No sound comes from headphones
Headphones are plugged in, but there is not sound from them when audio is playing.
The phone is muted
Go into the sound settings and make sure that the phone is not muted. Pushing the volume up button on the volume rocker when inside of a media app will usually un-mute it.
The volume is low
The volume may be too low for you to hear the audio coming from the headphones. In this case, use the volume up buttons to increase media volume. From the sound settings panel you should be able to increase the volumes of other things like notifications and alarms in addition to media volume.
The headphone port is broken
The headphones port may be damaged due to wear or water damage. In this case it will need to be replaced.
The headphones are broken
The headphones you using could be broken. Try another plugging in another device and see if the audio plays through it.
Author
with
Nicholas Van Beek
593 Reputation
1 Guide authored
UMass Dartmouth, Team 1-9, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-9, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G9
3 Members
60 Guides authored
3 Comments
my keyboard has stopped working. the touch screen is working. I get a message: "unfortunatley the LG keyboard has stopped ".
I rebooted. took battery out cleared cashe, it still doesn't work
jenny - Reply Share
My LG G2 D620 will not move beyond the intro screens. I have tried factory reset on the buttons but NOTHING works. I think it is time to apply a hammer to it and nail it to the wall with the rest of the crappy useless dead phones.
elspeth909 - Reply Share
My LG G2 mini was blinking during start up, therefore i cannot open the menu. i have tried factory reset on the botton but nothing works. what can i do?
michaelangelomancera14 - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 8,027
