Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet Will Not Charge
When cable is plugged in, charging symbol is not shown
Defective Charging Cable
  • Replace the charging cable with another micro USB cable. If the tablet begins to charge, then the original cable may be faulty.
Charging Port is Clogged
  • Check the charging port located on the top of the device for any debris. Lint and other foreign material can clog the port and prevent the power adapter from fully connecting. Clean with a small cotton swab to remove any debris.
Tablet Does Not Hold a Charge
Tablet powers off sooner than it should
Multiple Apps Open
  • Having multiple apps open will drain the battery of your device faster. Tap the home button twice fairly quick to view all open apps. Close out apps by swiping them to the right.
Faulty Battery
  • Check to make sure the light appears on the power adapter and the charging port is clean of debris. If the tablet only powers on when the power adapter is connected, the battery is faulty.
Touch Screen Unresponsive
Screen is frozen on most previously viewed page
Device Froze/Crashed
  • If the screen is unresponsive first try performing a factory reset by holding the power button for 5 seconds until the device turns off. Release the button, wait 5 seconds, then turn the device back on.
Faulty Screen
  • If a factory reset was performed and the screen is still unresponsive but the device will power on and off, and the screen lock button will work, the screen is faulty and needs to be replaced.
Distorted Audio
You have trouble hearing from headphones
Headphones not in fully inserted.
  • Ensure headphones are fully inserted by pushing firmly until an audible “click” is heard.
Headphone Jack Clogged
  • If the headphone connector will not fully plug in, check to see if any lint or other foreign debris is inside. If a clogged headphone jack is suspected, clean with a cotton swab
Headphone Jack Faulty
  • If headphone is fully plugged in and there is no sound in headphones, the headphone jack is faulty and needs to be replaced.
Phone Won’t Load Past Boot Screen
When the tablet starts up, it becomes unresponsive and won’t advance past the boot screen
Faulty Motherboard
  • If a factory reset was attempted, but the device will not power on,and a working power cable is plugged into the device, the motherboard is faulty and needs to be replaced.
Author
with
Edward del'Etoile
1 Reputation
0 Guides authored
6 Comments
Not coming on not showing charge
sweethearted djTia - Reply Share
Tablet not coming on not
How to hard reset a jlab pro7 tablet
brooks.dale - Reply Share
My tablet is protected with a locked screen and the person that gave it to me forgot the password
Karen Alexander - Reply Share
The person I got my tablet from has a locked screen and he forgot the password..so I can't get it to boot
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 3,196
