Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device not showing up in bluetooth settings:
Pairing, akin to adding a new contact to your phone's list, involves a bit of initial setup, but facilitates swift connections in the future. This process, illustrated through the analogy of phones and speakers (or headphones), entails acquainting your phone with the speaker, referred to as pairing. It's important to note that while the discussion predominantly centers around phones, the concept applies universally to tablets, laptops, computers, and any other Bluetooth (BT) source device.
Not Properly Activating Pairing Mode
To initiate pairing, you typically need to activate pairing mode on the speaker, which may involve pressing specific buttons. Instructions vary, but generally, pressing the speaker's BT button, either briefly or for a few seconds, prompts pairing mode, often indicated by a sound or blinking LED.
If standard procedures fail to activate pairing mode, consulting the owner's manual or relevant resources for the specific speaker model is advisable. Subsequently, accessing the BT settings on your phone allows you to search for and select the available speaker devices.
Upon completing these steps:
  • Your phone and speaker become paired.
  • Your phone and speaker establish a connection, enabling music playback.
It's worth noting that akin to the Contacts list on your phone, your phone can pair with multiple speakers and headphones simultaneously.
One side of the headphone not working
A common issue with the JBL Tune 710BT is that one side of the headphones occasionally stops working. There are several causes for this issue, and there are two different methods to resolve this issue. One method involves using an auxiliary cord to reset the headphone connection. A secondary method involves disconnecting and re-pairing the headphones completely. Depending on the issue with the headphones, one of the solutions may solve the issue of one side of the headphones not working.
Faulty Aux Cable Connection:
Connect to bluetooth on desired device. Insert the aux cable and the headphones will turn off. Pull out the cable and then turn the headphones back on. Repeat until the desired side works again. You will know if the desired side is working again as soon as you hear the turn on sound. If the first method failed to solve the sound issue, please try this second method as an alternative solution.
Defective Bluetooth Connection
Disconnect headphones from device. Go to bluetooth settings on the device, and “forget” or unpair the headphones from the desired device. Manually re-pair the left and right headphone sides: power on the headphones and press the buttons 3 times on each side to initiate re-pair. Pair headphones back to the desired device, and the sound should be fixed.
If issues persist, contact manufacturer support for assistance.
Connections to non-standard devices not working
A common issue with the JBL Tune 710BT is that connections to non-standard devices fails to work. By non-standard devices, this refers to devices such as a laptop, video game systems, and televisions.  There are several causes for this issue, and there is one main method that goes through many of the common issues  to resolve this problem . There may be an issue with the connection cable, drivers, firmware, audio settings, or a factory reset may just be necessary.
Connections Trouble
Check Connections: Ensure headphone cable is firmly plugged in. Inspect cord for damage; replace if necessary.
Drivers/Firmware Outdated
Update Drivers/Firmware: Update device drivers, especially for computers. Check headphone firmware; update if possible.Test with Different Devices: Connect headphones to another device to check functionality. Restart and Reset: Restart both device and headphones: Reset headphones to factory settings if applicable.
Faulty Audio Settings
Adjust Audio Settings: Confirm correct audio output settings. Access this via the settings of the connected device. It should be under sound settings within the settings category or even a connections panel. Adjust volume levels as needed via external device sound control.
Microphone not working
When you're ready to listen to a new show, record a voice note, or simply chat with friends, the last thing you want to encounter is a malfunctioning microphone. This can be especially frustrating if you're using a trusted accessory like the JBL Tune 710BT headphones. A non-working microphone can disrupt communication, affect productivity, or simply hinder your enjoyment of your device.  Whether you're dealing with a Bluetooth connectivity issue, incorrect settings, or an unknown glitch, this guide is designed to help you navigate through common troubleshooting steps to get your JBL Tune 710BT microphone working again. We'll walk you through checking connections, adjusting device settings, and other tips to resolve the issue.
Improper Connections
First, ensure that your JBL Tune 710BT headphones are properly connected to your device. If the connection is not secure, the microphone might not work as expected. Turn off the headphones and turn them back on to establish a fresh connection. Make sure the headphones are fully charged.
Check Your Bluetooth Menu: Go to the Bluetooth settings on your device. Ensure that the JBL Tune 710BT is not only paired but also connected. There's a difference between being paired and being actively connected. If it's not connected, select your JBL Tune 710BT from the list of available devices to establish a connection.
Select Your Headset as the Input Device: On your device, navigate to the sound settings. This process varies depending on your operating system. For Windows, right-click the sound icon in the system tray, then click 'Sounds'. Under the 'Recording' tab, select your JBL Tune 710BT as the default device. On a Mac, go to System Preferences > Sound > Input, then select your JBL Tune 710BT.For mobile devices, this is usually automatically managed, but you can check app-specific settings to ensure the correct microphone is selected.
Sound Control Panel Improper Settings
Adjust Settings in Sound Control Panel: If using a computer, further adjustments can be made in the sound control panel. In Windows, within the 'Recording' tab mentioned earlier, you can also click 'Properties' and adjust levels and other settings. Ensure that the microphone is enabled and the volume is appropriately set.
Connectivity/ Hardware Problems
Restart Your Device: Sometimes, a simple restart of your device can fix connectivity or hardware issues. Restart the device you are trying to connect your JBL Tune 710BT to and try connecting again after the restart.
Additional Tips:
  • Firmware Update: Check if there are any firmware updates available for your JBL Tune 710BT. Updating the firmware can resolve some issues.
  • Check with Another Device: Try connecting the headphones to a different device to determine if the issue is with the headphones or the original device.
  • Contact Support: If the problem persists, consider reaching out to JBL customer support for further assistance or to check if there's a hardware issue with the microphone.
By following these steps, you should be able to troubleshoot and potentially resolve the issue with the microphone on your JBL Tune 710BT headphones.
Headphones are connected but no sound playing
Encountering silence when you expect music, a podcast, or a call's audio through your headphones can be a perplexing issue, particularly when they're visibly connected and should be functioning correctly. This common problem can arise due to a myriad of reasons, ranging from simple oversights in volume settings to more complex connectivity issues. Whether you're using your headphones for entertainment, work, or communication, it's crucial to resolve this issue promptly to get back to your audio experience.  In this guide, we'll explore the steps you can take when your headphones are connected but not emitting any sound. We'll guide you through verifying and adjusting your audio settings, ensuring that your headphones are selected as the preferred output device, and checking the volume levels to ensure they're set correctly. Additionally, we'll provide tips on restarting your device and inspecting headphone connections, which can often resolve more elusive audio issues. Let's dive in and bring the sound back to your headphones.
Output Device Error
Change Output Device: Confirm device audio settings. Select headphones as the output device on desired device through accessing the settings. Underneath the settings category, most devices will have a sound interface or connections interface to modify output device. Adjust Volume: Ensure volume is not muted. Increase volume to an appropriate level via connected device volume controls.
If issues persist, consider restarting the device or checking headphone connections for further troubleshooting.
Frequent Disconnection from the device
In the realm of modern technology, the scenario of headphones disconnecting from devices is not uncommon, presenting a frustrating obstacle to uninterrupted audio enjoyment. These disconnections can stem from a variety of causes, each demanding its own unique remedy.
Multi-Device Interference and Compatibility
Frequent disconnections often stem from compatibility issues or external interference. Not all devices seamlessly support automatic reconnection, potentially leading to interruptions in audio playback. Moreover, factors such as multiple connected devices or manual pairing with a different speaker can interfere with the connection process. To mitigate these issues, users should troubleshoot by manually reconnecting the headphones through the device's Bluetooth settings. Additionally, managing connected devices and disconnecting unnecessary ones can alleviate interference issues, ensuring a stable and uninterrupted connection.
Power and Battery Issues in Headphones and Devices
Low battery levels in either the headphones or the paired device can contribute to sporadic disconnections. To address this, users should regularly monitor and maintain adequate battery levels in both devices. Charging devices promptly after use ensures uninterrupted connectivity during audio playback, minimizing the risk of disconnections due to power-related issues.
Software Glitches and Updates
Software glitches or outdated firmware on either the headphones or the connected device can disrupt Bluetooth connectivity. To resolve these issues, users should regularly update the firmware of both devices. Keeping the firmware up to date can address software-related glitches and enhance overall compatibility and performance, ensuring a seamless connection experience.
Physical Obstructions and Lack of Proximity
Physical obstructions or excessive distance between the headphones and the paired device can impede Bluetooth signals, resulting in intermittent disconnections. To optimize connectivity, users should minimize environmental interference by moving away from potential sources of electromagnetic signals. Additionally, optimizing the physical positioning of devices to ensure optimal proximity and line of sight can improve signal strength and reduce disconnections, enhancing the overall reliability of the connection.
What to do if none of these fix the issue?
In instances where troubleshooting efforts fail to resolve the issue, it may signify a hardware defect, necessitating further inspection or professional assistance to rectify the problem effectively.
Author
with
Nicole
52 Reputation
0 Guides authored
3 Comments
Great resource for troubleshooting the JBL Tune 710BT! Super helpful for anyone experiencing connectivity or sound issues. JBL makes amazing headphones, and guides like this ensure we can keep enjoying them
Deepika - Reply Share
Not turning on after charging
Ernest Samuels - Reply Share
Kenneth Redd - Reply Share
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 156
All Time: 7,987
