Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
JBL Charge 5 will not Turn on
Your JBL Charge 5 speaker will not power on.
Device is not Charged
If the device is not charged, plug the JBL charger cord into a power outlet. A dot will be visible when the device is charging.
JBL Charge 5 Power Button Not Working
Make sure the device is not in Service Mode. If it is not, Buttons may be blocked by dirt and debris. Tilt the speaker and blow, brush, or polish switch contacts if you can reach them. Please refer to our button repair guide. If the charger cord is dead, replace the cord. The battery inside may no longer recharge due to age, excessive charging, or heavy use. Please refer to our battery replacement guide here.
JBL has a Dead Battery
If the JBL speaker will not turn on, it may have a dead battery. Dead batteries are caused by a variety of reasons such as harsh temperature conditions, under or over charging, and more. Please refer to our battery replacement guide here.
JBL has a Faulty Motherboard
If all other options do not apply to your device, your JBL may have a faulty motherboard. If the motherboard has suffered damage, it could potentially cause the device to not work. Please refer to our motherboard replacement guide here.
JBL Charge 5 is Not Charging
Your JBL Charge 5 Speaker will not charge.
Broken Cable/Faulty Charger
If your Charge 5 speaker will not charge the issue may be with the charging cord rather than the speaker itself. This may occur because of improper cord use bending the end of the adaptor severing one or more of the wires inside. Your charger may also have damage to the head or portion that enters the speaker. This issue can be solved by replacing the charger.
Power Outlet May Not Be Energized
The AC or car adapter for JBL Charge 5 may not have appropriate output and the device is not receiving power. Check the receptacle has enough power, reset breakers if tripped, and if the outlet has a light switch that controls it, then be certain the switch is in the ON position, or try another outlet.
Device is in Service Mode
You must connect the device to an external power source, such as an AC charger adapter because your device does not power ON or OFF when in service mode. When plugged into an external source, the speaker powers ON without pressing the Power button and runs on an internal battery. To turn it off, you must unplug the device from an external power source. Only the buttons needed to take the speaker out of Service Mode works on this setting.
Faulty Battery
Your speaker may not be charging because the battery is faulty, either it has lost its ability to be charged over time with regular use or was damaged another way. Regardless, the battery can be easily removed and replaced to solve this issue. Please refer to our battery replacement guide here.
The Speaker is Defective
The Speaker Might be Defective when the JBL Charge 5 is Not Charging. Even with the proper power supply and working battery, the current that gets to the battery may not be appropriate. This can happen when the JBL Charge 5 battery management circuits fail. These systems read the battery status and switch off the charging current when they deem the battery full. Because the electronics in this unit are quite small, the system boards are too intricate for a non-expert to change. Please refer to our speaker replacement guide here.
Bluetooth Connection Isn’t Working
Your JBL Charge 5 Speaker will not connect to your device through Bluetooth
MotherBoard Malfunction
A factory reset may fix the issue, if too much data is stored at a time a new user will not be able to connect. A reset can be performed by holding the play, and power-up button. The motherboard may have suffered damage causing connection issues or not being able to connect at all. Please refer to our motherboard replacement guide here.
Bluetooth Button Failure
The Bluetooth button itself may be damaged, this prevents the pairing sequence.
JBL Charge 5 Sounds Distorted
Your JBL Charge 5 Speaker is producing sounds such as buzzing, muffled audio, or static.
Speaker is on Incorrect Audio Mode
There is a party mode button for the speaker when pressed will connect it to other speakers of the same type within a certain range. This can affect the audio quality of your speaker. All you need to do to turn it off is by turning the speaker off and on again.
Speaker is Blown Out
This can happen when when the speaker is worn down or by playing loud music to the extreme. What happened is the volume and sound causes the speakers to break themselves. In order to fix this issue you will need to visit our speaker replacement guide here.
Your JBL Charge 5's Buttons are Not Working
Your JBL Charge 5 Speakers buttons will work or interact with the device.
Button Blocked by Debris
When buttons do not press down, they may have debris such as dust, dirt, or other material that prevent the button from springing into position, or even causing the button to remain stuck in place. It is recommended to remove the button to clean the debris underneath. Please refer to our button replacement guide here.
Buttons are Worn Down
After time, buttons can get worn down by long-term usage. If this is the case, the buttons must be replaced. Please refer to our button replacement guide here.
Faulty Motherboard
After clearing debris or replacing buttons does not work, the motherboard of the device may be faulty. If the motherboard is working incorrectly, the buttons will not respond to input. If this is the issue, please refer to our motherboard replacement guide here.
Author
with
Kat Whaley
1,144 Reputation
6 Guides authored
8 Comments
My JBL Charge 5 wont charge and after careful review, the issue is the flex cable that conects the charging module to the motherboard.
just thought it might be usefull to add it as a possible failure within the troubleshooting steps.
JD Jaramillo - Reply Share
Suppose, if everything is still working on the speaker, but the Bluetooth doesn't sound quite as loud. Or what you would call distortion, but quiet not really high pitch. Does that mean the speaker is blown? Because I'm pretty sure it aint the passive radiators on the sides because they're still moving and the speakers have had before that broke in the past. When that wasn't working and moving, it was broken by this speaker.I've had it for 3 or 4 years and everything's working on it.But 1 day I just turned it on.And I just sounded like it was going in and out.The sound was like the sounds.Psychic was a problem coming from within the woofer or the tweeter area
OlePussINfocker96 - Reply Share
My charge 5 well turn on then off it well only charge to 10 percent and has no sound
Shane - Reply Share
JBL CHARGE5 ND Version Flex Cable button Key Cable Charge Cable LED cable Connector
Azizul Hoque - Reply Share
My JBL charge 5 Bluetooth range can't reach 10meters with my phone. What should I do?
YONDU TONNY - Reply Share
Past 24 Hours: 19
Past 7 Days: 167
Past 30 Days: 652
All Time: 22,751
