Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Defective Buttons
The play button is jammed and I can’t use it
Dirt Buildup
The button may be jammed due to accumulated dust behind the button. Try to clean around the button to remove grime. to clean the buttons you can use a small brush or an air duster. If this doesn’t work, you may need to remove the front panel to clean the area. Please see the front panel removal guide for instructions.
Overlapping Buttons
when two buttons get stuck together, try pressing the buttons around it to set them free. if this does not work, try wiggling the buttons gently. tapping around the area can also be helpful but be careful when attempting this, you can damage parts inside.
CD Skips
While the CD is playing, the soundtrack skips through the current track, sometimes skipping it entirely and moving on to the next track
Dirty/Scratched Player
The inside of the CD reader may be causing the CD to be skipping. Spray with an air duster in the compartment, and try playing the CD again. If the CD keeps skipping, check the CD itself. If the CD is fine, then the CD reader may be damaged, and would need to be replaced.
Dirty/Scratched CD
Wipe the CD gently with a cloth, preferably a lint-free one, to clean and smooth the surface. If the CD keeps skipping, it may be scratched permanently and is the sole problem.
FM/AM Weak Signal
I have trouble listening to the radio because of too much static.
Blockage of Signal
Test the audio through different parts of the house and make sure there is nothing wrong with the speakers by playing music through a different setting. AM/FM signal might be weak in different areas and the location of the boombox may need to be changed.
Faulty Antenna Wire
If the audio sound is distorted when listening in the AM/FM setting, try adjusting the antenna in different ways and make sure is fully connected to the device. You should fully extend the antenna wire to make sure the wire is not peeled, electrical tape can be use to fix a peeled wire.
Cristina Ruiz
137 Reputation
1 Guide authored
CSU Fullerton, Team 2-5, Bruce Fall 2016 Member of CSU Fullerton, Team 2-5, Bruce Fall 2016
CSUF-BRUCE-F16S2G5
4 Members
48 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 28
All Time: 795
