Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device will not Power On
"My tablet is not turning on"
Faulty power button
Press power button and wait for it to turn on. If tablet doesn't turn on, then try resetting it. Hold home and power button down together for 5 seconds. If there is a faulty power button then the button needs to be replaced or table needs replacing. Check repair guide for help.
Defective Battery
Plug in tablet to charging cable. If tablet doesn't start charging either check power source, then check cable. If neither work and tablet doesn't start charging, then the battery is defective. If there is a defective battery then the battery needs to be replaced. Check repair guide for help.
Insignia Wi-Fi windows tablet charging issue
"My tablet will not charge when I plug it in"
Defective Battery
Charging Port Malfunction
Check charging cable for any imperfections, plug in. If device doesn't begin to charge, check cable with another device. If there is a charging port malfunction then you need a new USB or to fix the charging port. Check repair guide for help.
Faulty Charging Adapter
Check charging cable for any imperfections, plug in. If device doesn't begin to charge, check cable with another device. If the adapter is faulty, then you need to purchase a new one. Check repair guide for help.
Broken Screen
"I dropped my tablet and the screen is cracked"
Cracked Screen
If there is a crack in the device screen then it needs to be replaced. If screen is coming apart from tablet, screen will need to be replaced. Check repair guide for help.
No Display on LCD Screen
If screen remains black when tablet is on, then the LCD screen is malfunctioning and will need to be replaced. Check repair guide for help.
Audio isn't Working
"I can't hear anything from my tablet"
Faulty speaker
If audio is not working then it can be caused by faulty headphones or speakers. If the audio problem isn't being caused by the headphones or speakers, the problem is likely with the tablet itself and will need to have the speakers repaired. Check repair guide for help.
Kristen Gismondi
108,893 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
86,246 Guides authored
1 Comment
We're is the reset button oris there a sequence that I can push the movie start
Darryl Secrist - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 994
