Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Failure to charge
When the device is plugged in, the device fails to connect to the provided power supply and start charging.
Faulty power cord
Check to ensure power cord is completely together. Check charging light to make sure there is a proper connection. If cord is secured, light is on but still no charge consider purchasing new charging cord.
Faulty Charging port
Check to ensure a tight fit in-between charging port and cord. If charger cord is confirmed functional, try cleaning out charging port. If problem continues consider charging port replacement.
Faulty battery
If your device turns on but only when charging cord in attached, your battery is faulty. Purchase and replace with a new battery.
Failure to hold a charge
When the device has been charged, the device's power does not deplete in a slow consistent way but more quickly than it should drain.
Faulty power cord
Faulty battery
Freezing during use
When using the device, the software freezes up to a point where the user cannot continue using the device.
Lack of RAM
When using device, if it freezes when running more than one program simultaneously, then your device may not have enough RAM. Try closing programs you are not using or install a RAM managing program. If that doesn’t work consider installing more RAM.
Motherboard not working properly
When using your device, it freezes during normal operation, try a hard reset. If this doesn’t fix the problem consider purchasing a new motherboard and replacing it.
Speakers not working
When trying to use the device for any application, no sound will come out of the speakers when there is supposed to be sound.
Loose connections
If speakers work intermittently or are distorted check to ensure speaker connections are secure inside device.
Faulty Speakers
If connections are solid and speakers still symptoms or don’t work at all, you may have faulty speakers, consider replacement.
Screen Failure or Broken Screen
The device's screen is not responding, picture on screen does not look normal or the screen itself is cracked.
Device is frozen
Your device might just be frozen and a hard reset should fix the problem .
Dead pixels
If part of your screen looks like it is missing some of the picture or it is a different color than the rest of the picture, your screen has dead pixels and should consider a screen replacement.
Cracked screen
If the screen has a crack caused by physical damage, consider a screen replacement.
Unresponsive touch screen
If the touch screen is not responding to your finger, check to ensure touch screen is enabled. If it is enabled and screen is still unresponsive consider screen replacement.
5 Comments
Audio Driver- No Sound after updated to the Fall Windows 10
HPLong 12/02/17
Huey Long - Reply Share
how can you check if touch screen is working do not know where to look
john - Reply Share
Where do you find touch screen contols
john - Reply Share
my issue is that keyboard seems to no longer connect when attached to the tablet. what could be the potential causes/fixes?
thank you
mkm - Reply Share
Where do I find a screen replacement for this, I have ordered it and it only comes with the glass but the guy at the tablet shop says that he needs the digitizer as well because the digitizer does not come off the broken glass as it is glued on. He asked me to order the glass and the digitizer together or if it comes as 2 pieces then order the glue as well, please advise.
Mike Beauregard - Reply Share
