Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet Will Not Power On
Tablet does not turn on when the power button is pressed.
Drained Battery
If your tablet fails to turn on, ensure that the battery is charged. Try plugging the charger into the tablet and waiting a few minutes.
Faulty Charger
It is possible that your tablet is fine but your charger is broken. Try using a different functional micro-USB charger. If it still does not charge your tablet, there may be an issue with the micro-USB port on your tablet. Check out this guide to replace your motherboard.
Faulty Battery
If the charger is functional and plugged in and you are still experiencing problems with the battery holding charge, consider replacing your battery. Replace the battery using this guide
Faulty Motherboard
If replacing the charger or battery still does not charge your tablet, it may be an issue with the micro-USB port on your tablet. Check out this guide to replace your motherboard.
Tablet Not Responding
The display remains the same and is unresponsive to touch.
Needs to be rebooted
Restart the Tablet by holding down the power button for several seconds until it is off. Press the power button again to turn it on.
Not Enough RAM
Your tablet is using too much computing power. Try closing some applications that are running. This allows the tablet to run smoother.
Faulty Screen
If your screen is cracked and does not respond to touches, your screen is most likely damaged and needs to be replaced. You can replace the screen by following this guide.
No Sound
The tablet does not make any sound.
Muted Sound
Make sure the volume is not muted. Try pressing the volume up button on the side of the tablet. Another way to turn up the volume is to go into your settings and then go to sound.
Faulty Speaker
If the volume is turned on and you still do not hear any sound, consider replacing your speaker by following this guide.
Failure to Record Audio
Voice calls, voice memos, and voice commands do not function properly.
Dust in Microphone
Your ports may have collected dirt or dust. Clean out the dust by using a compressed air duster to carefully blow out the ports.
Faulty Microphone
If your tablet still does not record audio, consider replacing your microphone by following this guide.
Tablet is Overheating
While you are working, your tablet randomly shuts off without notification.
Exposure to Hot Environments
Remove the tablet from any hot environments and put it in a cool environment.
William Boyden
388 Reputation
3 Guides authored
13 Comments
Hi I have the 10.1 insignia and the touch screen won't work I've already tried rebooting it and still won't work what can I do at this point
ferna014 - Reply Share
Same problem too
db204696 - Reply Share
I am having the same problem. Even after rebooting my tablet does not respond. It stays Lonnie on INSIGNIA logo…HELP!
ohu1rdl - Reply Share
I have a insignia 10.1 silver .My camera won't rotate.no camera icon only camcorder icon is on the startup of the webcam.????
Bobby lee Miller - Reply Share
I have a insignia tablet that turns it self off once I turn it on
Untwan Tate - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 24
All Time: 11,430
