Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer Will Not Power On
The computer will not turn on when the power button is pressed.
Faulty Charger
Ensure that the power adapter has all connections fully seated, from the wall outlet to the computer's charging port. Check for a charging light on the computer and the adapter itself. If there is no light, replace the charger.
Faulty Battery
Connect the power adapter and press the power button. If the computer runs with the power adapter plugged in, but shuts off when the charger is unplugged, replace the battery.
Computer Will Not Boot
The computer will not boot or wake up from sleep mode.
Bootable Device
There may be an external device interfering with the computer's normal boot sequence. Unplug any USB drives and remove any SD cards from the computer's ports, then try again.
Faulty Display
Plug an external monitor into the computer's HDMI port. If the external monitor displays correctly, your built-in display may need to be replaced.
Reset the RAM
The computer's RAM may be overheated or over capacity. Reboot the computer; if problems persist, remove and reinstall the RAM modules to ensure they are seated correctly in their motherboard ports.
Operating System Corruption
If the above steps don’t resolve the issue, you may need to reinstall Windows. You can attempt a repair install using your Windows media, or a clean install if you have your important data and applications backed up. Contact your computer manufacturer for installation media and instructions if needed.
Touch Screen Not Responding
The touch screen is not responding to touch and swipe commands.
Touch Screen Is Frozen
Unplug the power adapter from the computer, then press and hold the power button for 20 seconds. Reboot the computer and test the touch screen again.
Touch Screen Is Disabled
Open the Windows Device Manager, expand the Human Interface Devices (HIDs) node, and double-click on the last USB device listed. Open the Power Management tab and uncheck the "Allow the computer to turn off this device to save power" option, then click OK and reboot the computer.
Faulty Screen
If the above steps do not resolve the issue, the touch screen may need to be replaced.
WiFi Not Connecting
The computer experiences a weak WiFi connection or disconnects from the WiFi network.
Incorrect WiFi Driver
The computer’s WiFi device driver may be out of date, or a third-party driver may be interfering with the factory driver. Reinstall the Lenovo WiFi & Bluetooth Wireless Networking driver. The manufacturer recommends using version v1.04.0213 or higher.
Increase WiFi Power
Windows may be limiting power to your WiFi network adapter. Open the Windows Device Manager, right-click on the wireless network adapter and select Properties, then go to the Power tab and uncheck the “Allow Windows to manage power to this device” option, then click OK.
Congested WiFi Channel
WiFi networks can operate on one of 11 channels; your network may be operating on the same channel as other nearby networks, causing interference. You can change which channel your router uses in the wireless network settings on your router; check your router's manual or manufacturer's website for instructions specific to your model. Channels 1, 6, 7, or 11 may be the strongest.
Computer Blue Screens
The computer unexpectedly shuts down with a blue error message screen.
Device Driver Conflicts
Your computer's device drivers may be out of date or misconfigured. Download and install the latest drivers for every device the computer has.
Operating System Not Updated
Your Windows installation may not be up to date. Run Windows Update and ensure all updates download and install without failing.
File System Corruption
Blue screen errors can be caused by problems with your file system. You can run the Windows System File Checker to replace and repair missing or corrupted system files.
Faulty Memory
Your RAM modules may be malfunctioning or damaged; you can test them with a utility like the Windows Memory Diagnostic and, if necessary, replace them.
Faulty Hard Drive
Your hard drive may be malfunctioning or damaged; you can run a diagnostic from your hard drive manufacturer to determine if it’s functioning correctly. If not, backup your data and replace it.
6 Comments
Good Day,
My laptop did not show above problem.
The display has a horizontal line in the middle of the screen. Why is that happen
laipingee - Reply Share
Glemt passord for innlogging og forsøkt 8 ganger. Pc er nå stengt for flere forsøk og kan ikke åpnes. Har dere et tips for hvordan fikse dette? Mvh Ingunn
Ingunn Bakke - Reply Share
Laptop is plugged in and the charging light goes on. When I press the power on button, the button lights up for a couple of seconds and then it is off. Laptop does not go on at all. Any advice on what I can do to fix the problem, except using a hammer… haha. Thank you
Remond Matthee - Reply Share
Hello there
My Laptop has a display problem. Because I tested the steps above and I can't find a short or anything else. Even if I connect an other display ober HDMI there is no response. Strange thing about: The engine is running perfectly fine. No Lamps that may lead to a systemfault. Has someone an Answer for me? Thanks
maurizio thaddey - Reply Share
My Lenovo is a POS......will not buy another
Albert Einstein - Reply Share
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 49
All Time: 4,326
