Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Headphones Won’t Power Up With USB Cable
The headphones are connected to power via the USB cable and is not working.
Misadjusted USB Cable
Check your usb cable to make sure both ends are connected properly. Try unplugging your cable at both ends if both seem to be inserted properly.
Faulty USB Cable
Try using another usb cable. If it works, then your USB cable was faulty and you need a replacement cable.
Faulty USB Connector
If you’re not getting power, make sure your supply’s USB port is working properly and supplying power. If it is, and it still isn’t turning on, then your USB port may need servicing.
Faulty Solder Joints
Open your device and see if there are any bad solder joints on the circuit board where the USB port is. If the solder appears cracked or broken, carefully try reflowing solder on each terminal, or heat the solder up until it’s reached it’s reached its melting point and has liquified, and allow to cool down.
Speakers Are Not Playing Any Sound
The headset is connected and powered up, but there is no sound.
Loose Audio Cable Connection
The cable you are using may be loose or misadjusted. Check all connections to ensure that they are properly connected.
Faulty Audio Cable
Check your audio cable for any damage and try using another cable to see if your cable is bad.
System Settings
Check your system’s audio settings to make sure it’s outputting audio to your headphone jack. Also check the volume settings to make sure it’s not toggled off or low.
If your device is still not working after checking your device’s cables and audio settings, it may be an internal issue. Disassemble your device and check for any loose or broken solder joints that may be causing the issue.
Broken Speakers
If your device seems to be in good standing and powers on, the speakers may be blown or bad.
Poor Sound Quality
The headphones are connected and powered, but the sound quality is poor.
Misadjusted Audio Cable
Check if your audio cable is properly plugged in and both ends are making a good connection. If it’s connected properly and is still poor sound quality, try unplugging your cable and plugging it back in.
System Settings
If your audio is clipping or is of poor quality, check your system’s settings to make sure your volume is at a good level and any settings that may affect the audio quality output of your device.
Broken Audio Jack
If your cable is in working condition, and your audio quality is still poor, the audio jack may be bad. Open your device and check if the solder joints are okay, and if they are then you can try replacing the jack.
Loose Connections to Speakers
Disassemble your device and see if there are any poor solder connections on your speakers or wires that feed from the motherboard to them. Inspect the wires themselves for cracking or bare wire, and if so then they need to be replaced. Reflow the solder at both ends of the wire to ensure a proper connection between the motherboard and speakers.
Microphone Will Not Function Properly
System Settings
Check to make sure your system is feeding the microphone audio from your device. If it’s not, check all of your device’s connections and change your system settings to the correct microphone input and sensitivity level.
Broken Audio Jack
If your cable is in working condition, and your microphone is still not working, the audio jack may be bad. Open your device and check if the solder joints are okay, and if they are then you can try replacing the jack.
Loose Microphone Jack
Faulty Microphone
Your microphone piece itself may be the problem. Check to ensure it’s solder joints are good, and if so, you may need to purchase another microphone end and replace it.
Author
with
Alex Derkautsan
363 Reputation
1 Guide authored
3 Comments
I have hypercloud headset. I thought that the mic was broken as I can hear perfectly but my mic won't pick up my voice and people in my party get like white noise coming from me. I bought a new mic and a new controller but still have the same problem. Any ideas anyone?.
Wayne Slater - Reply Share
I have also had issues with mic- I stream and have it all the way up on Audio both in OBS and in my settings but i practically have to be eating the mic? I have even done the latest and greatest firmware update but nothing seems to work. The audio source in OBS should not be at 100% for people to hear me.
Preston Odenbrett - Reply Share
Out of nowhere my headset started blasting and super exposing all the sounds my Xbox was making, I’ve reset my Xbox and turned the headset on and off and it still has the issue?
ranman12 - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 124
All Time: 27,437
