Husqvarna models from 2009 onwards have an Autotune feature which automatically calibrates the carburetor. If you are running your saw in new weather conditions or at a different elevation, follow the steps to correctly tune the carb:
Reset Husqvarna Autotune
For low idle settings, start the saw.
  • Let it run for a few seconds to warm and then kick off the high idle by pulling the throttle.
  • Start a three minute timer. At the end of three minutes your idle should be tuned.
High Speed Procedure
For the high speed or full throttle reset, you'll have to make a large or long cut.
  • Bury the tip of the bar a few inches and run a six foot cut.
  • About 20 seconds in, you may hear the engine tune and significantly change frequencies during operation. Continue the cut for 45-60 seconds.
Your saw is tuned. If it doesn't sound correct, verify it has the correct firmware installed.
Husqvarna service technicians can perform a master reset, though these resets shouldn't be done unless the AutoTune unit has been set incorrectly to compensate for a mechanical failure in the engine, e.g. a broken intake rubber, a cracked muffler, a missing or clogged air filter, or after a major repair of the engine or fuel system.
Additional Resources
Autotune Test Procedures
Husqvarna Autotune's Dealer Diagnostic Tool
nicO
15,990 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
70 Members
3,048 Guides authored
1 Comment
Hi Nico,
Thanks for this brilliant instruction. 2 questions: Is it suitable to autotune 3.0? In the full throttle reset: 45 - 60 sec on top when I hear the motor tuning or is 45?- 60 sec total time?
Greets husky123
Husky123 - Reply Share
Past 24 Hours: 16
Past 7 Days: 103
Past 30 Days: 353
All Time: 13,630
