Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera Will Not Take Pictures
The camera does not capture images when you press the shutter button.
Memory Space
Check to make sure that you have enough memory space for photos in the settings, sometimes if you do not have enough space on your phone, the camera will not allow you to take photos. If there is not enough memory space, please see the following guide
Faulty Camera
Once you have ensured there is memory space and that there is no debris, see the following guide for Camera Replacement.
Speaker is Too Quiet
The speaker is quiet even when the volume is in the maximum setting
Volume Button Assembly Is Broken
After checking volume buttons for debris, see the following guide for Volume Button Assembly Replacement.
Speaker Is Blown Out
After checking that your volume settings are set to max in the settings, find if there is noise coming out of the phone at all. If there is no noise at all, it could be a software issue. If the noise is unclear or too quiet, it is most likely the speaker itself. If it is the speaker itself, please see the following guide for Speaker Replacement.
Screen is Not Responsive
The screen does not react when pressed on
Poor Touch Response
If when touching your phone screen, it does not react, or reacts badly, see the following guide for Screen Replacement.
Broken Screen
See the following guide for Screen Replacement.
WiFi Will Not Connect
The phone keeps searching for wifi but never connects
Antennae Problems
After checking that the wifi is set to "On" on your device and you have a known network to connect to, see the following guide for Antenna Replacement.
Device Will Not Turn On
When the power button is pressed, the phone will stay off
Power Button Assembly Is Broken
After checking the power button for debris, see the following guide for Power Button Assembly Replacement.
Inadequate Battery Life
Check and see if your phone will cut on once plugged in, if not, see the following guide for Battery Replacement.
Slow Phone Performance
The phone has a delay whenever an app is opened or apps take a while to load
Poor Battery Performance
After checking the extent of your battery drain using an application from the Google play store, see the following guide for Battery Replacement.
Memory is Insufficient
Clear out internal storage by deleting photos and excess apps.
2 Comments
My huawei ascend st was run over and screen broke where can I get it repaired
Monica Krog - Reply Share
I changed battery in my huawei ascend xt android phone and now the speaker phone and ringer don't work , why?
Thank you
robin.leah - Reply Share
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 747
