Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Hover Board Will Not Turn On
Hover board will not power up.
Hover Board Isn't Charged
If the hover board will not illuminate nor function, it may not be charged. Plug the power adapter into the hover board and a 120V power socket. If the charging light illuminates, the hover board is charging. If it does not illuminate, read the other possible issues below.
Broken Power Button
Connect your hover board to its charger. Make sure that the charging light is illuminated, and wait until the battery is fully charged. After the battery is fully charged, press the power button. If the hover board does not turn on, then the power button may need to be replaced. You can replace the power button using (this guide).
Hover Board Won't Charge
Hover board will not receive charge input.
Broken Charging Port
Ensure your charging cable is properly plugged into the charging port on the hover board as well as a functioning 120V power socket . If the charge light does not illuminate on the device, it is not charging properly. Check the charging cable and the charging port for visible damage. If the charging cable is the issue, you can purchase a new one from the manufacturer. If the charging port needs to be replaced, you can replace the charging port using (this guide).
Hover Board Loses Charge Quickly
Hover board battery drains quickly
Deficient Battery
Connect your hover board to its charger. Make sure that the charging light is illuminated, and wait until the battery is fully charged. If your hover board is still experiencing an unusually short battery life, then the battery may need to be replaced. You can replace the battery using (this guide).
Hover Board Is Riding Slowly/Won't Steer
Hover board is slow, unbalanced, or inoperable.
Connect your hover board to its charger. Make sure that the charging light is illuminated, and wait until the battery is fully charged. If your hover board is still experiencing insufficient power output that is causing the ride quality to be slower than usual, then the motherboard may need to be replaced. You can replace the motherboard by using (this guide).
Hover Board Won't Steer Properly
Connect your hover board to its charger. Make sure that the charging light is illuminated, and wait until the battery is fully charged. If your hover board is still experiencing balance issues which make it difficult/impossible to ride, you may need to replace the motherboard. You can replace the motherboard by using (this guide).
Author
with
Tyler Peterson
96 Reputation
0 Guides authored
UC Davis, Team S7-G5, Lore Fall 2018 Member of UC Davis, Team S7-G5, Lore Fall 2018
UCD-LORE-F18S7G5
3 Members
36 Guides authored
34 Comments
Only one side of my overboard is working
Colleen Inzerillo - Reply Share
Hoverboard overheats quickly
Xavier Lopez - Reply Share
My hover-1 rocket will charge & keeps beeping. Will not recalibrate.
Dennis Hawes - Reply Share
Xhover 1 ultra is charged but doesn't powerup all connection are good and battery has 41 voslts. Is there away to test power switch to see if it's working osrd not
Mark Lutz - Reply Share
Did you ever receive an answer to your question? I'd like to know as well. Same issue. Thanks!
Janet Sinclair - Reply Share
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 49
All Time: 36,717
