Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Battery not charging
The board is not responding to charger when plugged in.
Faulty charger
Make sure the charger is plugged into a grounded wall outlet.
Make sure there is no dust or debris in port.
If the green light located on the charger is not on and everything is plugged in properly, your charger is faulty.
Faulty Battery
Charge board your for 2.5 hours.
If board won’t turn on or won’t hold a charge your battery is faulty. Click here for directions for replacing your battery.
Board will not connect to remote
Board and remote are charged but they won’t connect.
Electrical malfunction
Power off your board and remote.
Power them back on and attempt to connect them.
Connect your board and remote
Press and hold the power button on both the board and remote for 3 seconds.
If this doesn't work, there may be debris in the buttons. Clear if possible.
If this still doesn’t work, you may need to open the casing and clear out debris or replace the buttons.
Electrical Failure on board
The battery is charged, but the board won’t respond to the direction.
Board motor seized up
Turn off your board and your remote, then power it back on.
If this didn’t work, try the next option
Board motor has failed
It may be that the wheel is jammed. Check for rocks, twigs or other debris.
Clear out any blockages if possible.
Board is overheating
Power off the board and allow it time to cool.
Board battery has failed
Plug your board in and allow it to charge.
When you operate your Coast the board quickly overheats and shuts off.
There is potential damage to the charge port
First check to see if there is dust or debris in the charge ports and clear this out if possible.
If the problem persists, you may need to replace your charge port.
The battery is overcharged
You should only charge your board for 2.5 hours and never longer than 4 hours.
Be sure you are using the correct charger. Sometimes using a different charger can create problems.
If your battery is damaged, you can refer to this guide on “Replacing your battery”.
Riding your coast on rough terrain or up hills
Using the coast in this way can place strain on the motor.
Turn off your board and allow time to cool.
Motor Doesn’t Work
The board and remote are charged but the motor won’t respond to the remote.
Make sure the board and the remote are paired
Hold the power button down on both the board and remote for 3 seconds, a blue LED light will flash indicating that it is pairing, once the pairing is completed the light will stop flashing.
Faulty Motor
If the motor won’t turn on even when charged, you may need to replace the motor.
Failure to move
Board stops moving while you are riding it
Motorized wheel is jammed
Check for possible blockages in the wheel and attempt to unblock it.
Electrical Failure
Power off the board and remote and then turn them on again.
Overheating
Turn off both the board and remote and wait for the motor to cool down.
Battery is low
If the battery is 15% or lower the board will turn off, Charge the board and remote as soon as you can.
Author
with
Jace Oppenlander
569 Reputation
4 Guides authored
5 Comments
having problems getting the bell to work. everything else works fine. thanks.
joe dipietrantonio - Reply Share
Just purchased a Hoover-1 all star combo and the hoverboard will not turn on
Bullington - Reply Share
The board was great for the first week now as I hit the throttle it starts to go then stops. Now it won’t even turn on
Joshua Edson Naylor - Reply Share
Board charges up but don't go. Just a beeping noise. Coming from board. Also will it run without remote.
Frank Stamos - Reply Share
My remote is just blinking blue and everything is charged
JAA Nicole - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 36
All Time: 1,717
