Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Thermostat is Unresponsive to Adjustment Attempts
You can change the temperature adjustment but the HVAC system does not respond to your changes.
Dead or Faulty Batteries
If the thermostat is a newer digital model, try replacing the batteries. This usually involves removing the faceplate to access the battery compartment. Remove and replace the faceplate carefully so as not to bend the connection pins.
Dirty Thermostat Unit
Slider needs cleaning
Older thermostats that use a slider to set the temperature have moving parts that can become coated with dust and grease over time. Remove the face-plate and clean slider and slider housing.
  • With a cotton swab, lightly dipped in rubbing alcohol and clean the area.
  • Using short bursts from a compressed air electronics cleaner, blow dust and debris from the thermometer spring and housing interior.
Faulty Thermostat Unit
There is no easy remedy. Replace with new unit.
*link*
Heating or Cooling System Does Not Respond
HVAC system does not react to thermostat changes
Press SYSTEM button to set system to Cool. Make sure the temperature is set lower than the Inside temperature.
  • Check circuit breaker and reset if necessary.
  • Make sure power switch at heating & cooling system is on.
Faulty/Defective Thermometer
The coil springs may be broken or damaged. There is no easy remedy to fix this with the unit and it still accurately display the temperature reading. Replace whole thermostat with a new unit.
*link*
Thermostat Fails to Stop
Your Honeywell RTHL3550D fails to turn off HVAC system once set temperature is achieved
*link*
Faulty/Defective Circuit Board
Any of the circuit board components may be broken or defective. Inspect these carefully.
May also be due to corrosion. If corrosion is found, clean thoroughly with rubbing alcohol and cotton swap.
If cleaning techniques don't work, some of the circuit board components may be broken or defective. Unfortunately, replacement parts are not easily available, so thermostat must be replaced.
*link*
Thermostat is Physically Damaged
Casing is damaged; buttons, knobs, sliders are non-functional
There is no easy remedy. A face-plate or mounting plate from an old identical thermostat may be used. However, these parts are not sold separately and may be hard to obtain. Replace with new unit.
*link*
0 Comments
Past 24 Hours: 5
Past 7 Days: 9
Past 30 Days: 39
All Time: 2,723
