Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Car won't start
You've been sitting in your car, and nothing you do will get it started.
Check Gasoline
Before we pop the hood and start messing around and getting dirty lets check if there's any gasoline in the tank.
Dead Battery
If you've checked the gas level and your car still wont start, it might be because your battery is dead. Car batteries are usually easily accessible and are an easy fix.
Oil Change
Now if your car has a sufficient amount of gas and the battery still has juice, then it might be time for an oil change.
Dampness in Distributor Cap
If your car passes all of the previous tests then a leaky distributor cap might be the problem.
Door Problems
Door Handle is Loose or Won't Open
If your interior door handle feels loose, has no resistance, or stays in the open position, the return spring may be broken or the linkage clip may have snapped.
Replace the interior door handle assembly.
Author
with
Matthew
1 Reputation
0 Guides authored
1 Comment
Hi, could anyone help us on how to locate and fix the trouble of a Honda Civic 2001 model automatic transmission.
1.) The engine starts but it shuts off once we switch on the A.C.
georgenieverajr - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 3,132
