You may have experienced this on your controllers before: your character starts moving with no input, your aim creeps upwards or to the side while trying to stay still, your controller seems to be possessed by a ghost that constantly wants to move ever-so-slightly to the left. This phenomenon is referred to as “joystick drift” and is exceedingly common in gaming controllers. It isn’t because you dropped the controller or tossed it across the room after a particularly intense gaming session; rather this is a design flaw inherent to the mechanism behind most controllers on the market: the potentiometer.
Why do joysticks drift?
A potentiometer is simply a variable resistor that forms a variable voltage divider. This might not mean much if you’re unfamiliar with electrical components and theory. All you need to know is that the voltage divider output changes depending on the stick's position. Your controller reads this voltage and translates it to a coordinate. Say 0.1V means “down” and 0.9V means “up”. Center might be defined as 0.5V. Potentiometers are not super accurate so these calibrations are usually done at the factory, meaning that the controller always expects 0.5V to be the center.
As you move your joystick, it moves a conductive wiper against a resistive contact pad, which varies the resistance, and thus output voltage. You move your joystick up, and the resistance and output voltage increase. You move the joystick down, and the resistance and output voltage decreases. There are two potentiometers on each stick for horizontal and vertical movement, so your controller reads the voltages from both to determine where you want your character to go.
The problem arises when these resistive contact pads get worn down over time due to friction. You can imagine how many repetitions this system gets after just an hour of gaming. Every time you move your joystick back and forth these contact pads lose a minuscule amount of material. Over time, this alters the resistance of the contact pads. Once the resistance value of the neutral position changes—boom, joystick drift. Because your controller is reading a different voltage than expected while stationary, it interprets it as joystick input, resulting in your character slowly walking off that cliff while you get a snack.
How do hall-effect joysticks eliminate drift?
Here’s where Hall-Effect sensors come in. Where the potentiometer joystick uses a resistive pad and wiper to vary the voltage, a Hall-Effect joystick uses a contactless alternative: magnets.
In a Hall-Effect joystick, the conductive pin (the wiper) is replaced by a magnet, and the resistive contact strip is replaced by a flat conductor (Hall Element) that is sensitive to magnetic fields.
As electrons flow through this material, the magnetic field effectively “pushes” them to one side of the conductive material or the other depending on the field polarity.
When the joystick is moved, the sensor detects which side electrons were pushed to in the conductive material and interprets this as movement. This all happens without physical contact eliminating any chance of friction wear to the sensor!
Voila! A contactless joystick input method—one that can drastically increase the lifetime of your controller and is far less prone to drift. Whereas a potentiometer joystick is nearly guaranteed to fail eventually, a Hall-Effect joystick could hypothetically last the entire lifetime of the controller.
Author
with
Austin Blakely
23,462 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
8 Comments
Found this very interesting about joystick. So I assume I can change my potentiometer stick on my Xbox controller to hall effect as I have been experiencing drift. Thank you for this information, a lot of information.
FireFlyone. - Reply Share
You definitely can, but I would do some research. There are a few Hall Effect replacements specifically for Xbox, but I have seen varying reports of quality. And you will need some solder skills for this too, but it's not too difficult if you've got solder basics under your belt.
Alisha C - Reply Share
Muchas por estas enseñanzas, para un cubano pobre ha sido de mucha utilidad porque, nadie explica esto pero si cobran la reparación de manera desmesurada, muchas gracias.
Joaquin Guerra - Reply Share
Genial gracias desde Argentina
888iiiii - Reply Share
Hello, I've stumbled on this while trouble shooting my HE custom PS5 controller. Great info here and I wanted to ask how to manually adjust the sensitivity of the HE? In my controller the L3 is way too sensitive and no calibration tool can help in adjusting it. I assume it's a hardware issue.
bardeesi - Reply Share
Past 24 Hours: 89
Past 7 Days: 616
Past 30 Days: 2,506
All Time: 66,406
