Phone does not turn on
You cannot get your HTC EVO Design 4G to turn on
Phone battery is not charged/Phone battery is dead
The battery may be dead or drained. Try plugging the charger into the phone. If it does not turn on, it may be a problem with the battery and may have to be replaced. (reference to replacement guide)
Bad display
When attempting to turn the phone on, the phone may make noise as though it were working normally but the screen does not display any picture. This may indicate that the screen is bad and may need to be replaced.
Phone is not charging
After plugging your HTC EVO Design 4G, the device still does not turn on
Bad charger
It is possible that the charger itself is the problem and needs to be replaced. Try using a different cable and wall adapter to determine if this is the issue. If possible, try testing the cable with another device. Be sure to test the wall charger on more than one outlet. To determine if it is the wall adapter, connect the phone to your computer using the USB cable only.
Something is wrong with the port
If you suspect that there might be something wrong with the connecting port, it may be that it is unclean or slightly damaged. Try blowing into the port to remove dust and other particles that do not belong.
Phone will not connect to the internet
Your Snapchat won’t reload, your tweets won’t post, and you can’t respond to that Facebook notification from last week
Mobile data is not enabled
From the home screen choose All apps> Sprint Zone> Help> I Need Help. This will automatically check voice and data connections. If either of these connections is a problem, choose Update Profile and check to see if the problem is resolved. If the problem persists, perform a soft reset by powering off, removing the battery for 30 seconds, replacing it, and turning it back on.
No available connection
Try finding an area with an available connection.
Phone camera is taking blurred pictures
No matter what you try, none of your photos come out Instagram worthy
Broken/dirty lens
If your pictures are not coming out clear, it could be due to a broken or dirty lens. Try cleaning the lens and checking the lens for cracks or imperfections. If there are cracks, the lens may need to be replaced.
Camera is not focusing before pictures
Make sure when taking pictures to allow the phone’s camera enough time to auto-focus on the subject. Otherwise, there could be something on the lens itself that could be messing with the auto-focus function.
Phone freezes, performs slowly, turns off unexpectedly
Your phone just isn't what it used to be
Low memory
Try freeing up space by deleting all sent or received text messages, transferring pictures onto computer using the USB cable and deleting them on your phone in order to free up space.
Battery is dead
If the battery is dead contact your phone provider and request a new battery for your phone. If it still doesn't work this could be an internal problem that relates to the battery.
Author
with
Nassika
1 Reputation
0 Guides authored
2 Comments
The display was fixed and repaired but the phone turns on and the display light is hardly working what is it
ROBERT S JORDAN - Reply Share
Incoming calls in audible
Art Brush - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,003
