Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
iPAQ Will Not Turn On
The device does not illuminate or power on after pressing power button.
Faulty Battery
After adequately charging the device, check to make sure the battery is properly inserted. If the device does not turn on, or will only turn on if left plugged in to the charger, a replacement battery will be needed.
iPAQ Display Screen Does Not Fully Light Up
The screen doesn't have its normal bright display.
Defective Backlight
If the brightness is properly adjusted and the device is powered on, and the screen is still too dim, the backlight will need to be replaced.
Cracked Display Screen
Display can't be read because of cracks in the screen.
Screen Replacement
Through disassembling the device and careful screen removal, you can install a new and functioning display screen.
Unresponsive Buttons On iPAQ
Pressing iPAQ's buttons gives no feedback.
Button Replacement
If after completely restarting the device the problem persists, each individual button can be ordered online as replacement parts.
iPAQ Is Beginning To Run Poorly
Over time, the device's performance has steadily decreased.
Dust Removal
If the device is running below par, and you've tried restarting the device, this could be caused by excess dust buildup inside the iPAQ. This can be solved disassembling the device, and cleaning the dust with compressed air.
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 40
All Time: 713
