Student In Progress
This wiki is being worked on by hardworking students.
HP Probook 450 G8 System is Frozen
The HP Probook 450 G8 froze. It may not be responsive.
Overheating
The system is frozen and the underside is really hot.
- Make sure it is on a hard surface and not on anything soft that could retain heat or block airflow.
- Additionally, clean the dust buildup inside the cooling vents by using compressed air. Here is a video on how to use the compressed air can.
- Power it off and allow it to cool off for 10-15 minutes.
Insufficient RAM
There could be too many tabs or apps open that are causing the freezing.
- Open task manager by pressing Ctrl+Alt+Delete and ending any tasks that are taking up too much space.
- If freezing is a recurring issue, getting more RAM installed could be a solution, as recommended on Cyberguy.
*If no other solution works, here is a guide on replacing the Memory Stick (RAM).
Software Issues
Multiple software code could become incompatible or corrupted, leading to system interference.
- Simply updating the operating system (OS) might fix any bugs. Always install updates when they are available.
- Windows is able to install recommended computer drivers to ensure system stability.
Malware
Malicious software can also cause freezing.
- Running a scan through an antivirus software can detect any malware.
- If any malware is found, remove the threat and restart your laptop, according to Olympia Computer.
- To defend against future malware issues, installing antivirus protection could be a solution. Here are some recommendations.
0 Comments
