Student In Progress
This wiki is being worked on by hardworking students.
HP ProBook 440 G6 Loud Fans
When using your laptop for a prolonged time, the fans start to get very loud.
Loud mode on:
Go down to the windows search bar and search for HP command center. On the “Thermal Profile” tab, select the quiet mode.
Unclean air vents:
If the first fix doesn’t work, try this instead:
- Power down your device by pressing and holding the power button for approximately fifteen seconds.
- Ensure that there is nothing blocking the fan vents on the sides of your device.
- Use a vacuum to remove the dust from the vent underneath and on the side of the computer.
- When you turn on the computer again, make sure to place it on a hard surface. Placing it on soft surfaces or cloth surfaces might result in a restricted or blocked airflow, which can cause overheating or potential damage if prolonged restriction/block occurs.
0 Comments
