Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Press power button, LED lights come on, but screen remains black and doesn't boot
"This problem is common in this vintage of HP laptop. The root problem, according to exhaustive Google searches, is apparently the graphics processor chip tends to overheat and work itself loose from the motherboard. There are several fixes out there that can work, all of them risk permanent damage to your computer so be careful."
There is no repair for this. Reflowing the GPU is a patch fix, and truly NOS GPUs are no longer available. Recover the data from the laptop, and migrate it to a new computer or external storage device if you opt against pulling the hard drive out and putting it in an enclosure.
Also, this page has a lot of good data on fixing video problems in this model.
Whining Noise From Hard Disk
You are using the computer and your hard disk starts to emit a whining noise.
Change the Power Scheme
This is normal in certain notebook PCs. Reduce the sound by trying a different power scheme: go to Start -> Control Panel -> Power Options.
Optical Drive Not Detecting Disk
You have a CD or DVD in the drive but your computer won't recognize it.
Check the Drivers
First remove any disks from the CD/DVD drive. Check for the optical disk driver in the Device Manager. Go to Start and type 'device' in the search. Open Device Manager. In the window, expand CD/DVD Drives. If there is not a listing for your driver, you may need to reinstall the driver. To do this, highlight each driver, right click, and select delete. Then click Scan for hardware changes near the top. Windows will scan your computer for drivers that are needed.
Notebook Shuts Down or Restarts Unexpectedly
On a critical error the notebook could shut down or restart without notice.
Disable This Recourse in the BIOS
One way to prevent the PC from an unexpected shutdown or restart is to disable the option by restarting the computer. Once you have done this press F8 to open the Advanced Boot Options menu. Select the Disable automatic restart on system failure option. Restart the computer to accept the change. Now the computer will display an error message on critical failure which you can use to help diagnose with HP's help.
Modem Stops Working in Windows XP
The modem on this notebook may stop working after waking up from sleep mode.
To fix this issue go to Start -> Control Panel -> Performance and Maintenance -> Power Options. Select "Never" for both the System Standby and Turn Off Hard Disks options.
Defective Battery
If your battery gets scalding hot, this can help.
HP started a voluntary recall program in May of 2009. Some batteries would overheat or have problems holding a charge. If you have any of these problems, check this website with your product and serial number to see if you are eligible for a replacement.
High pitched noise from Fan
"Hearing a high pitching sound from fan"
Whining noises may be fan-related. Perhaps your laptop changes the speed of the fan slightly while on battery and that speed change could cause a problem with the natural harmonic resonance of the fan mechanism. This is the same reason why a shopping cart with a squeaky wheel will stop squeaking if you push it faster or slower. I would change your power settings, change it to where whether it's on battery or power that it performs the same.
Fan Runs constantly and Pc operates slower than normal
The electrical components in a PC generate heat, and fans inside the PC help move the air to keep the components from getting too hot. Excess heat will cause the fans to run constantly, damage components, and limit the speed of the CPU. All of these problems with high power and high heat will cause applications to work slower than normal. One of the main functions of the BIOS is to monitor the temperature and adjust the operating conditions. While the sound of the fan running all the time can be annoying, it may the first clue that your PC is running as efficiently as possible.
To help your PC run as cool and efficiently as possible, try the following corrective action.
Update the BIOS
After PCs have been released, HP may distribute an updated BIOS to manage the fan, CPU power loads, and other components. To see if there is a newer BIOS, you should check what version of the BIOS is currently on your PC, and then look on the HP Drivers and Downloads page for updated drivers.
To locate the BIOS information on your PC, start the HP Help & Support Center, and look for system information. The utility will list the type of processor (Intel, AMD), and the BIOS version. To find a possible updated BIOS, go to the Downloads and Drivers page, enter the model and OS of your PC, and look at the version number and date of the BIOS drivers.
More Info
More info can be found at the HP Troubleshooting Official Website
Author
with
Ben Hirsch
3,877 Reputation
10 Guides authored
Cal Poly, Team 21-33, Regan Fall 2010 Member of Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Members
120 Guides authored
6 Comments
I had the black screen and just a momentary HDD light. One of my RAM sticks is bad. With that stick out, the DV6700 boots fine and reports 2G of RAM if you look for the number (in "My Computer, I think).
I will get a new 2G stick for it -- maybe 4G, if it will take a 4G. Yes, it runs noticeably slower on 2G.
bloggerccc - Reply Share
My fan was making noise so I opened it up to clean it. After closing it, the laptop boots for only few seconds( black screen, only touchpad light is on, fan is on) but eventually, everything goes off after seconds. Local technicians have recommended a new motherboard but I want to know if there is any help. If not what type of motherboard dyu recommend. Don't know the laptop's exact name. It has switchable graphics(intel hd 3000 and ati radeon 7400m) , beats audio, fingerprint reader, 8 i7 cpu's, two memory cards, 15.6 inches.
Jerry Asare - Reply Share
There is an ad from Microsoft entitled CHANGE IS GOOD on my screen and I cannot get rid of it, I’ve rebooted it unplugged it and got no results?
can anyone help
Kit Tisdale - Reply Share
I had a black screen first lap top try to reboot with noise on fan but nothing show up on the screen now nothing reboot no fan noise nothing just the bleu light goes on 3 sec and off any help?
Tima - Reply Share
Just bought this laptop and it popped up with an error code and the restarted in the middle of me doing stuff wtf
Juan Luna - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 48
All Time: 40,462
