Flash Drive Not Detected
When you plug in your flash drive the computer does not display it being found anywhere.
Defective USB Port
Try connecting the flash drive to all available USB ports on the computer to see if the issue can be narrowed to a specific port.
Try connecting another USB device into all of the ports on the computer to detect if the flash drive is faulty.
Defective Flash Drive
Connect flash drive to different computer, to see if the issue is being caused by the flash drive itself.
Individual Key Not Working
The computer is slow to respond, or has no response to certain keystrokes.
Dirty Keyboard
Dust and debris can collect under the keys, which can lead to their malfunction. Use compressed air to blow any debris out of the keyboard.
If this does not solve the problem, gently pry off the troubled keys to see if there is anything still stuck underneath, which may still be inhibiting their function.
Key Mechanism Is Broken
Remove one troubled key and one functioning key, examine the mechanism beneath both to see if the faulty one is visibly different or broken. Compare resistance of depression between both. If there is a noticeable difference between the functioning and faulty key issue is likely a broken key which will require a full keyboard replacement to fix.
Alternatively, use external keyboard to circumvent the troubled key.
Keyboard Doesn't Respond When I Type
Keyboard doesn't work
If the keyboard does not respond when you type, it could be the result of hardware issues or software issues.
Faulty Keyboard
Connect an external keyboard to your computer and see if it works. If it is does work, then you need to reconnect the internal keyboard connectors. If that does not work, then replace your keyboard. See the "Removing HP dv5000 Keyboard" repair guide for instructions.
Bad Mother Board
If the external keyboard does not work, then you need to replace your mother board.
Laptop Screen Remains Black After Start-up
Black or blank screen
Dead RTC battery
Especially if the computer is 5 years old or older (or has been left unplugged for a long time.) The RTC battery allows your PC to keep track of the time and date between boots, and maintain the CMOS setting needed to boot itself. If the battery is low, the CMOS settings may get scrambled, and prevent it from booting.
The RTC (Real-time clock) battery is a watch battery (usually a #2032.) It is located under the Wi-Fi card, in the same bay as the RAM memory. Remove the big regular battery, unplug the power, then remove the RTC battery. Before inserting the new RTC battery, flip the PC over, and hold the on/off switch for 10 seconds to completely discharge any remaining charge, and clear the CMOS memory. Flip the machine over again, and insert the new RTC battery.
Loose Hardware Component
If a black screen arises, it means a critical component of the laptop is damaged or missing. In most cases, the component is loose because the computer was dropped. The components most common are the hard drive and the RAM.
Bad Mother Board
If the components are secure, the mother board might be broken. A replacement mother board will then be required.
Laptop Shuts Off When Power Cord Is Removed
No power source available
Dead Battery
If a laptop cannot hold a charge on its own, even for a minute, then the battery is most likely dead. Batteries can be bought from the manufacturer or a local battery store.
Laptop Doesn't Turn on
Computer won't boot
Bad Power Adapter
Test to see if the laptop runs fine on the battery. If the battery is discharged, borrow a battery or a power adapter. If either one runs fine, then the power adapter needs to be replaced.
Not Enough RAM
There may not be enough RAM to boot the operating system. Unless the RAM inside the computer is less than the required amount for an operating system, the RAM is either dislodged or faulty.
Hard Drive Failure
The hard drive may have been erased. If this is the case, reformat the hard drive and re-install the operating system. If the hard drive is damaged or corrupted, you'll need to replace it.
Bad Operating System
The operating system may be corrupt. Try running an Operating System off a CD or a system restore if possible (if a backup exists). If this fails, re-install the operating system.
Poor WiFi Performance
WiFi connection is always weak. slow internet, WiFi disconnects sporadically.
Poor Network Connection
Large networks can be slowed down dramatically by high numbers of users. Try connecting to a small local wireless network, to compare quality of internet connection.
Router Issues
If you are using a household wireless router, disconnect it for 5 minutes to reset the network connection.
Internet Provider Issue
Connect your computer to a form of wired internet i.e. Ethernet, to make sure that the problem is not being caused by your internet provider, or a fault in their system.
Speakers Don't Work
No sound is produced when performing normal functions like listening to music, watching videos, and playing games. Speakers are non-responsive volume button.
Volume Level
Check both computer volume settings, as well as each specific programs audio settings.
No Volume Control
Use control panel to ensure volume settings and buttons are not locked.
Audio Out Destination
Examine audio settings to find where audio out signal is going. Make sure the settings are not trying to send audio to an external device which may or may not be connected.
Defective Speakers
Connect the computer to external speakers
After completing the previous speaker troubleshooting topics, if audio is played when connected to external speakers, but not through internal speakers, the speaker is probably broken and will need replacing.
Track Pad Is Non-Responsive
When you try to scroll, or move the mouse via the track pad, it does not react or is slow to respond.
Improper Settings
It is always best to start by restarting your computer, because this will ensure default settings are loaded, which could be the root of the problem.
Track Pad Accidentally Disabled
The track pad can be manually disabled, to check if it has been, click Start => search "mouse" => if disable toggle is selected, select enable.
Author
with
Farid Khoshnevissan
820 Reputation
4 Guides authored
Cal Poly, Team 21-34, Regan Fall 2010 Member of Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Members
132 Guides authored
6 Comments
My dv5000 is turn on and the fan work for 5 second without screen and then the fan is stop and the laptop not respond, no power of, no lcd screen, nothing just the lid lights. What can I do please
altaweel2004 - Reply Share
Hi altaweel2004, did you get the dv5000 fixed back in 2015 ? My college just handed me her old dv5000 with same problem Rgds Jan
Jan Glibstrup - Reply Share
I’m having that issue too!
Marcus Spano - Reply Share
I also have the same issue. Laptop turns on but screen stays black. Fan spins then stops. Cant access bios screen. Even the turn on off button doesnt work. To be able to shutdown laptop i disconnect power adapter and battery. What could cause such a issue? Is it the GPU or something else.
Efs - Reply Share
My DV5-1010e seem to have 2 failed mosfet's (VRM) near the power cable plug on MB, will change the mosfets on main 19V rail tomorrow.
ediflorianUS - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 11,221
