Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device won't turn on
Laptop fails to boot up when power button is pressed.
Power cord is unplugged
The device may not have enough power to boot up. Verify that the power cord is plugged securely into both the laptop and an outlet.
Battery is loose
The battery may not be inserted properly. Check to make sure it is inserted firmly and locks into place.
Battery is worn out
Your battery may have become worn down with use. Follow our guide to replace the battery with a new one. Hp Pavilion g7-2275dx Battery Replacement
Screen is damaged
The screen is flickering, is cracked, or has dead pixels.
Broken screen
You will need to replace your screen with an undamaged one. Follow our guide on how to swap out your screen. HP Pavilion g7-2275dx Screen Replacement
Device is overheating
Excessively hot air is coming out of the vents or devices crashes due to high temperature.
Inside of device is dirty
Unscrew the back of the laptop and clean out any visible dust build up with canned air
Fan is broken
Follow our guide for replacing the fan in your device. HP Pavilion g7-2275dx Fan Replacement
Device is running slowly
Slow response time and excessive lag.
Memory is fragmented
Open up the Disk Management and run it. This should improve the performance of your device.
RAM is maxed out
First check your device's system monitor. If your RAM usage is maxed out, follow our guide for replacing your RAM. HP Pavilion g7-2275dx RAM Replacement
Keyboard is damaged or not working
Sticky or broken keys
Broken keyboard
Follow our keyboard replacement guide. HP Pavilion g7-2275dx Keyboard Replacement
Author
with
John Sutton
1,588 Reputation
8 Guides authored
Cal Poly, Team 11-51, Amido Spring 2014 Member of Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Members
144 Guides authored
5 Comments
So it turns on and lets me log in then nothing
Cheryl Bernett - Reply Share
How do u know if the fan is broken
I turn the device on it lets me log in then nothing wbat does this mean
Turns on and just try's to boot forever, run the diagnostic and it says diagnosing your pic for hours no result
beautifulbuggs4 - Reply Share
Laptop is plugged in, when power button is pressed i can hear fans of something running, and power light is on, but screen doesnt turn on. Any ideas?
Asia Evans - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 8,019
