Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Insufficient Memory
Trouble downloading or saving files.
Faulty Hard Drive
Listen for any noise that is not the fan, if there is a clicking or loud sound then it is probably the hard drive. If you experience a lot of corrupted files, this is also another sign of the hard drive getting outdated or full. Refer to this guide to replace the Hard Drive…
Faulty RAM
Try switching between four or five different windows. If it is extremely slow, upgrading your RAM would help significantly. Another way to test is to try rebooting your computer. If that is very slow as well, a new RAM should do the trick.Refer to this guide to replace the RAM…
Insuficient Power
Refuses to hold power or power on.
Faulty charger
If the laptop can’t turn on or turns off shortly after you may have one of these issues. Check to make sure the charger is plugged in properly, if the charger is damaged or not properly plugged in they you will need to replace it. Refer to this guide to replace the charger…
Faulty battery
If the charger is working but its battery still isn't holding charge then you will need to replace the battery on the laptop. Refer to this guide to replace the battery…
Faulty Audio Outputs and Inputs
Hearing distorted sounds or no audio at all.
Faulty Speakers
Test the audio jack with different audio devices. Check various sound formats by going into your settings. Dismantle the laptop and replace the speakers. Refer to this guide to replace the speakers…
Faulty Audio Jack
Test to see how well the connection is between the speaker wire and the audio jack. If there is a loose connection try cleaning the audio jack by blowing in it or using a paper clip and lightly try to clean out any dust. If that doesn’t work try replacing the audio jack. Refer to this guide to replace the audio jack…
Blue Screen of Death
Screen turns completely blue.
Faulty Motherboard
Test to see if the computer freezes and causes the monitor to go to a blue screen of death. This could mean that the motherboard needs to be replaced. Refer to this guide to replace the Motherboard…
Out dated Software
Test to see if there is a new software update available. Try updating the device software to resolve the problem.
Damaged Screen Display
Any cracks or areas on the screen that are freezing.
Broken Screen
If there are cracks or scratches the hardened glass could be replaced. Refer to this guide to replace the screen…
Frozen or Unresponsive Screen
Another thing you can do is connect an external monitor to your laptop, to see if it's just the monitor or another issue, if the screen isn't responsive is to replace the screen by detaching it from the keyboard. Refer to this guide to replace the screen…
Connection issues
Trouble connecting to the internet.
Out Dated Internet Provider
First test to see if your Laptop could connect to different networks to see if its the provider not the device. Then check that other devices are connecting to the wifi as well, if so it may deal with internal parts.
Faulty Hard Drive
Replace the hard drive if the connection issue persists. Refer to this guide to replace the Hard Drive…
Andrew Silva
497 Reputation
3 Guides authored
UMass Dartmouth, Team 2-2, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G2
3 Members
84 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 349
