Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
HP ENVY Won’t Turn On
My laptop won't power on. The LED lights don't glow, the display is black, and the computer doesn't start.
Overloaded RAM
First, disconnect all peripheral devices and remove all USB devices and media cards. We want to test the computer not the accessories. Then, disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds. After that, reconnect the AC power adapter (but do not connect the battery). Press the Power button, look for glowing LEDs near caps lock and num lock keys, and listen for sounds of a disk drive and fan turning.
Faulty Power Socket or AC Adapter
Check the power socket on the computer and the AC adapter and cords for physical damage such as fraying or cuts. If damaged, they may need to be replaced for safety reasons.
Faulty Battery
If your computer still doesn’t turn on or hold a charge, your battery may be faulty. Replace the battery.
Screen Problems
The screen isn't fully functioning. There's problems like the display not turning on, or dead pixels in the display.
Overloaded RAM
This clears all information from the computer's memory without erasing any personal data. Performing a power reset might fix conditions such as Windows not responding, a blank display, software freezing, unresponsive keyboard, or other external devices locking up.
Dead Pixels
If the power reset method doesn’t work on your laptop, or there are still few lines on the screen, it might be dead pixels, and the screen might need to be replaced.
TouchPad Not working
The touchpad isn't responding to any finger touch, or movements.
Bad Drivers
A missing or wrong version of the software drivers might lead you into this issue. All you need to do is click the link below and find the driver that your laptop is missing or needs to be updated, then download and update it.
https://support.hp.com/us-en/drivers/sel...
Overloaded RAM
If the touchpad still not working after your installed or updated your touchpad driver, you might want to perform a power reset in order to solve this issue.
Broken Touchpad
If your touchpad has any physical damage, it may need to be replaced.
WiFi Not Working
WiFi assistant is on, WiFi lights stays orange, and no networks found.
Overloaded RAM
Disconnect the Battery & Adapter then press & hold the power button on Notebook for 30 seconds. Then turn on the unit and check if the wireless light turns on.
Outdated Drivers
Go to Device manager then uninstall the wireless drivers from Network Adapter and restart the unit and check if the light turns on. Then update the Bios & Wireless driver from HP website.
Drivers & Applications Recovery
Click start in search type Recovery Manager then click on it select Yes on User access control then select "I need immediate help". Select Driver & Application Recovery and select the wireless driver and install it. Finally restart the unit.
Faulty Wireless Card
Try reseating the wireless card, which will be on the back panel of your unit. If that does not restore wifi functionality, your wireless card may be faulty and may need to be replaced.
Speakers Not Working
Volume is up, but no sound is coming out of the speakers.
Wrong Output Method
Go into Device Manager and make sure that the sound output is going through your devices speakers, and that no bluetooth speaker or wired speaker is connected.
Incorrect Sound Drivers
Go into Device Manager and select Sound, Video and Game controllers. Uninstall the speaker drivers and go onto HP’s website and redownload and install the drivers.
https://support.hp.com/us-en/drivers/lap...
Screen Problems
Overloaded RAM
Dead Pixels
Bad Drivers
Overloaded RAM
Broken Touchpad
WiFi Not Working
Overloaded RAM
Outdated Drivers
Wrong Output Method
Sierra Hughey
23 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 977
