Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop will not power ON
When the power button is depressed, the laptop power indicators and lights do not respond
Battery is not charged
Plug power adapter into side port and make sure light indicator is ON. Press power button ON and allow the device to boot into Windows. Select and Click on the Start Menu and then select Control Panel. Go to Performance and Maintenance>Power Options. Select the Power Meter tab. If the power meter is low, allow it to charge up to 100% before unplugging the device.
Failing power socket
Plug the AC adapter into the side port. If the light indicator does NOT illuminate, gently pull the cable out and try and re-insert it into the port. While inserting, check for the indicator light. If it still fails to illuminate, check the connection from the power block to the wall socket. Secure these connections and check for the light. If it still does not illuminate, the power socket has a fault and replacement is recommended.
Failing AC adapter
If your battery will not charge fully, the AC charging adapter could be faulty. To test, ensure that all connections from the wall to the charging adapter are secured and then power on the device. Select and Click on the Start Menu and then select Control Panel. Go to Performance and Maintenance>Power Options. Select the Power Meter tab. If the Power Status does not indicate that it is charging, the adapter is failing and should be replaced.
Battery will not hold a charge
The battery charge indicator is found by following these directions: Select and Click on the Start Menu and then select Control Panel. Go to Performance and Maintenance>Power Options. Select the Power Meter tab. If you have verified that the AC adapter is good and charging the battery but you unplug the laptop and it does not stay ON for at least 5 minutes and the indicator falls dramatically, the battery should be replaced. Follow this link to the replacement guide.
Display Screen Failures
If images are not displayed or are distorted or there is damage to the screen
Screen will not display
If there is not an image on the display but the power button light is illuminated and flashing, the laptop may be in sleep or standby mode. Press the space bar key to wake the device. If the image does not appear, press the power button to wake the device. If the device still does not display an image, press and hold the power button for 3-5 seconds to perform a hard shutdown. Press the ON button again to begin the boot up process. You may have to select the "Start Windows Normally" option to proceed to the desktop.
Cracked or shattered screen
To replace a shattered screen, please follow this guide.
Keyboard missing keys
The keyboard keys appear damaged or are missing
Missing and or damaged keys
To replace missing keys, a key replacement kit must be purchased. Once this has been accomplished, follow the link to the replacement guide.
Keyboard is not responding
Keyboard is failing to enter text or respond to function commands
Faulty or failing keyboard
If a password is required to login, make sure the password text box is selected and try to enter your password. If no characters or keys are working, select the shutdown option using a mouse or the touch pad and allow the device to completely power down. Press the power button and allow the device to power on. Try entering the password again or entering text. If no text appears or the keyboard is still not working, refer to the following replacement guide.
Touch pad buttons are not working
The left and right click pad buttons are not responding
Device driver not installed correctly
Log into Windows. Select and Click on the Start Menu and then find and select Control Panel. Select Performance and Maintenance>System. On the System Properties window, select the Hardware>Device Manager. Check to see if there are exclamation points next to any devices. If there are exclamation point showing, the touch pad driver will need to be installed from the following location: HP Driver Site
Laptop will power ON but will not go past POST
The laptop power button is pressed and the laptop stops before logging into Windows
Hard drive failure or corruption
Power the laptop OFF. Wait approximately 3-5 seconds and then power the laptop back ON. If the laptop fails to boot properly and only a flashing indicator in the upper left portion of the display is flashing OR an error message regarding the HDD is displayed, refer to the replacement guide.
Memory module failure
Beep codes will be generated from the laptop speakers in the event of a memory module failure. If beep codes are present at POST, and the laptop will not boot up normally, refer to the following guide to replace a memory module.
Audio not working
No sound is coming from the speakers
Device driver is not loaded
Log into Windows. Select and Click on the Start Menu and then find and select Control Panel. Select Performance and Maintenance>System. On the System Properties window, select the Hardware>Device Manager. Check to see if there are exclamation points next to any devices. If there are exclamation points displayed on the sound devices, refer to the HP driver website to install the proper sound card driver.
Mute functionality is ON
To verify if the MUTE option is ON, boot to Windows, look at the lower right corner of the task bar for the sound icon (it resembles a speaker). Click the icon and DESELECT the option next to MUTE. Test sound again to verify the speakers are working correctly.
CD\DVD ROM drive failure
The CD or DVD is not working correctly
CD \DVD will not spin up when inserted
If a CD or DVD is inserted into the drive bay and the auto-run feature does not start the content, open Windows Explorer by double clicking the My Computer icon located on the desktop. Browse to the proper drive letter and double click it to open the content.
Cannot eject CD or DVD disc
If you can open the CD/DVD drive, verify that the tray is unobstructed and clean. Insure the drive is closed completely while in use and aligned properly. If you cannot open the drive, restart the laptop and try again. If the drive still fails to open, refer to the replacement guide to extract and replace the unit.
Samuel Lootens
203 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 46
All Time: 4,730
