Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop will not power on
The laptop is not powering on when pressing the on button.
Faulty charging cable
If the laptop is not powering on, first check to make sure the laptop is charging. If the charging light comes on, leave the laptop charging for a couple hours. For some laptops, it make take up to 24 hours for the laptop to fully charge. After fully charging the laptop, try turning the laptop on again. If the laptop still will not turn on, perform a hard reset on the laptop.
Faulty battery
If the laptop is only on when it is connecting to a charging cable, you may need to replace the battery. You can do that using this guide.
Screen is frozen
The screen is not responding.
Hard Drive Stuck
If the screen is not responding, it could be that the hard drive or other hardware is glitching. First turn off your computer. Then, perform a hard reset by holding down the refresh key and power button until the laptop restart.
Operating system won’t load (Chrome OS)
Chromebook has power, but the operating system is unresponsive or freezes.
External devices causing issues
Disconnect all unessential devices, like USB drives. Once all external devices are removed, turn on Chromebook. If the laptop continues to not start, perform a hard reset.
Software Out of Date
A hard reset erases all the memory on your computer, and forces the system to establish the software connections.
Press the power button and refresh button for five seconds. If this does not work, proceed to performing a system recovery.
System recovery needed
System recovery allows the computer to go back to its original factory settings.
Press and hold esc and refresh, then press power. Let go of power.
Laptop Will Not Charge
Laptop is powered on, but the battery is not receiving charge.
Damaged / dirty charging port
Look inside of the computer’s charging port to look for any signs of oxidation that would disrupt the flow of electricity into the battery.
Plug the charging cable into a working wall outlet and look for the light on the AC adapter. If you see no light, then the charging cable is faulty; consider replacing it.
Faulty Battery
The battery has come to the end of its lifespan and it’s time to be replaced. Follow this guide to replace the battery.
Faulty Audio Quality
Audio is muffled or there is no sound at all.
Damaged Headphones
If using headphones, ensure that your headphone wires are un-damaged and that your audio port is clean. Damaged wires can some times be identified by tears, lumps, and knots. A dirty audio port can be cleaned gently with a q-tip.
Audio tabs causing disruption
If you are not using headphones, ensure that the audio you are listening to is not corrupted by playing another audio file.
 Faulty Speakers
If none of these solutions work, your speakers or audio port may be damaged.
Author
with
Ella Portwood
711 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 53
All Time: 5,233
