Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop Overheating
The laptop is getting very hot to the touch.
Laptop is not in a well ventilated area
Check that the laptop is on a flat cool surface. Using a laptop while it is on something soft and fluffy prevents proper airflow. That is what can cause the laptop to overheat.
Cooling vents are blocked
If you laptop is on a flat cool surface but still overheating, check if the cooling vents are blocked by any objects in the. Check the sides and bottom of the laptop to see if there is anything unusual built up in the grates or vents.
The fan is not running properly
If your laptop is very hot but you do not hear the sound of a fan, it is likely that your fan is not working correctly.
Trackpad Not Working
You are trying to use the touchpad as normal but you see no movement of the mouse cursor.
Trackpad is turned off
If you have Windows 10 there is a way to turn your trackpad off. To check if it is off or on
  1. Open Settings
  2. Go to Devices > Touchpad
  3. Related Settings > Additional Settings
  4. Device Settings
Once there, check that the Touchpad is not disabled.
Drivers need to be updated
To check if you have the latest drivers updated, use the following steps to install the latest drivers:
  1. Go the HP Drivers and Downloads webpage. Enter your model number (HP 15-ef2025nr) and search.
  2. Select the HP 15-ef2025nr from the list.
  3. Search through the drop-down menu and click on your operating system.
  4. Select the category "Driver -Keyboard, Mouse, and Input Devices".
  5. Download the correct trackpad driver.
  6. Open your Downloads folder and complete the installation.
Trackpad needs to be reset
If none of the other methods work for fixing your touchpad, it may require a Hard Reset or Forced Reset. These instructions can be found in this document by the manufacturer.
Battery Not Charging
You plug your computer in, but the battery but the computer remains dead or with low battery.
Check Charger
If both ends of the charger are not plugged in correctly, the battery will not charge. Check the part that goes into the wall, part that connects to the "box" part of the box (located around the middle of the charger), and that that the charger snugly fits into the laptop.
Also check that there is no excessive rips, tears, or sharp bends in the charger. If there is, it is a possibility that the charger no longer works because of a short in the wire.
Check the Outlet
Verify that the outlet is working properly. Try plugging your laptop into a different outlet. If there is no power in the outlet, the computer will not charge.
Check Battery Health
If the charger and outlet are confirmed to be working, it is likely that battery is no longer in full health. To remedy poor battery health, you can simply replace the battery according to this guide.
Overheated Computer
If your computer is hot to the touch while charging, it may be affecting the charging. Make sure that the computer is on a flat cool surface. Leave the laptop on the flat surface until it is cool to the touch, and check if the battery is now charging. If your laptop does not stop overheating, see the Laptop Overheating section.
Device Not Turning On
You press the power button, but nothing happens.
If the light to the right of the charging port dose not light up when the charger is inserted into the charging port, this indicates that the device is not receiving charge. See the guide on troubleshooting battery not charging for further instructions on battery charging solutions.
Next check to see if the hard drive is active. On the right-hand side of the device there are two small lights. If the lights are blinking in a green or orange color, this indicates that hard drive is active, and the computer should turn on. If the lights are active, then there may be an issue with the devices screen. See the guide for diagnosing a malfunctioning screen.
If the device will boot while the charger is inserted but the battery is not holding any charge or is losing charge vary quickly the battery may need to be replaced. See the guide for battery replacement for this device.
Malfunctioning Screen
If the battery is charging the next step is to test the computer screen for a connection. First check to see if the screen brightness is too dark. Press the fn button at the bottom left of the keyboard and hold it while pressing the F3 button. This will increase the brightness on the screen.
Make sure that the computer has booted on, check the disk activity light on the right side of the laptop. If the screen is not on and there is no light being emitted at all and the device is powered on, then the screen may need replacement. See the guide for screen replacement for this device.
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 648
