Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
HP 15-ay103dx Troubleshooting
Released January 2017. Product # 1HZ43UA
Sticking Keys
‘’The keyboard is broken and won’t type.’’
Debris On/ Around Keys- External
Before removing any keys and checking for technical problems, make sure there is no physical debris inhibiting your keyboard from working correctly. Identify the problem keys and check under and around them. Use a can of compressed air to safely clean it. (CAUTION: compressed air can cause frostbite! Keep fingers away from the stream.) If there are any sticky substances, slightly wet a q-tip with rubbing alcohol and gently clean the affected areas.
Device Overheating
’’The device begins to overheat during long periods of usage.’’
Allow Proper Ventilation
While using your device keep your device on a sturdy, level surface. This will allow your device to “breathe” while you’re using it. Also be sure to keep the vents uncovered to avoid anything from blocking the air trying to circulate throughout the device.
Excessive Dust in Laptop
Overheating is commonly caused by a buildup of dust around the fan and/or the heat shield of the device. To fix this problem you don’t have to disassemble your device. Be sure to completely power off the device and disconnect the AC adaptor before you begin. Purchase a can of of compressed air and spray into the vents located on the side of the laptop to remove any dust accumulated.
Test for Hardware Failure
If the device continues to overheat after cleaning and allowing proper ventilation in the device, there may be a problem in with the hardware. To test your device for hardware failure go here for Windows 8 and up, and here for Windows 7. If any hardware failure occurs, replace the bad piece or contact HP for assistance.
No Sound/Audio
‘'There is no audio playing from your speakers.’'
The Audio Is Muted
Check to make sure you did not accidentally mute the volume or turn it down too low. Check in the lower righthand corner to see if the audio is muted. There will be a picture of a speaker with an ‘X’ through it. To fix this either click the volume slider or press the volume up button on your computer’s keyboard.
The Audio Device Does Not Work or Has a Faulty Connection
The audio device could be malfunctioning, or it could have a faulty jack or connection. Check the wire from your audio device to the audio port located on the side of laptop to see if there are any cuts in the wire. After you have checked this thoroughly, check that the jack is plugged in to the correct port and snug. The jack should ‘click’ into the port labeled by a headset. If there is still no audio, try another audio device like a pair of headphones, a wired speaker, etc. If the problem is resolved, then the previous audio device does not work correctly.
The Audio Mixer Is Not Set to Default
The audio mixer can be accessed by right-clicking on the speaker icon in the lower right-hand corner. Upon opening the mixer, look at all applications and devices and increase their volumes to 100%.
Speaker Is Formatted Incorrectly
Right-click on the speaker icon in the lower right-hand corner and click on ‘Playback Devices.” Double-click the box that says either “Speakers” or “Speakers and Headphones.” Next, click on the tab that says “Advanced.” From here, click the drop-down box beneath “Default Format” and choose various frequencies until the audio issue is resolved. Be sure to click “Apply” and then “OK.”
Audio Drivers Are Out of Date
If the audio drivers are out of date, they must be updated. To do this, you must first open the Start menu and search for the “Device Manager.” Scroll down and click on the drop-down arrow next to “Sound, Video, and Game Controllers.” Right-click on the “High Definition Audio” option and click “Update Drivers.” Search automatically for updated driver software and install the new drivers if you are prompted to do so. If you do install new drivers, restart your computer after you’re finished.
Unresponsive Touchscreen
'‘The computer does not respond or responds intermittently when the user attempts to make a command by tapping the touchscreen.’'
Computer Needs a Hard Reset
Sometimes the computer may be malfunctioning after an update or due to a few other issues. To complete a hard reset of your computer, make sure that it is any external cables and devices are unplugged (e.g. AC adapter, USBs with a phone/mp3 player, printers). Remove the Battery from the Battery Compartment on the underside of the computer, then press the Power button for 20 seconds to rid the computer of any leftover charges. Put the battery back in the computer, plug in the AC Adapter, then press the Power button to start up the computer. A Startup Menu will open with options- select “Start Windows Normally”
A Windows Update is Needed
The computer may need a windows update that will restore the touch screen. Use the Windows Search to search for and open “Windows Update”. If the option for an update is presented, click “Install Now”. Be aware that this may take some time and your computer will restart itself. If no updates are listed, click “Check For Updates”. If there are still none, continue to the next step.
Touch Screen Driver Is Disabled
The computer’s Touch Screen Driver may have accidentally become disabled. To enable it, use the Windows Search to search for and open “Device Manager”. Then, click on “Human Interface Devices”. Right-click the tab labeled “HID compliant touch screen” then click “Enable”. If the “enable” option does not show up, proceed to the next troubleshooting step.
Touch Screen Driver is Needs to Be Reinstalled
To reinstall the driver, go to the Search in Windows and search for and open “Device Manager”. Then, click on “Human Interface Devices”. Right-click the tab labeled “HID compliant touch screen” and select “Uninstall”. Confirm the uninstallation. Restart the computer to reinstall the touch screen driver.
Screen is Not Configured as a Touch Screen
The computer may not identify that the screen is a touch screen. To configure the display, go to the Search in Windows and search for and open “Tablet PC Settings”. On the “Display” tab of “Tablet PC Settings”, click “Setup”. Click “Touch Input” and follow the on-screen instructions for configuration. Once complete, tap your screen to see if it responds.
Author
with
Morgan Churchill
278 Reputation
2 Guides authored
1 Comment
Automatic repair couldn't repair you PC and it's looping
Keily - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,158
