Plug into iPod or iPhone
If the device will not turn on after using the left side button/switch to power it on, the left side button/switch may need to be removed and reinstalled or replaced.
This guide may help you with your left side button/switch problem. >>
[invalid guide link]
Also, if the device will not turn on, the internal headphone adapters may need to be removed and replaced.
Drained/Depleted Internal Battery
This device is plugged into and powered by iPod or iPhone devices. If the device will not turn on, the internal battery may need to be replaced, or recharged.
Defective Display
If the device is on, but the LCD is not visible, the wiring of the backlight may need to be replaced or mended. If the LCD contains extreme amounts of defective pixels, or is extensively cracked, the entire LCD may need to be removed or replaced.
This guide may help you with your LCD problem. >>
Griffin iFM 4027 LCD Screen Cover Replacement
Unresponsive Radio
If the radio will not play on the device, the radio’s internal FM transmitter may need replacement.
Unresponsive Central Button
The central button is the large, light colored button located in the center of the device, directly below the LCD screen. If your device is on and responsive, but unresponsive when the central button is pressed, you may need to adjust the placement of the central button inside of the device so that it is correctly aligned with the pressure points located on the circuit board or complete replacement of the button may be necessary.
This guide may help you with your central button problem. >>
<< Back to Device Page
Griffin iFM 4027
Alexander
101 Reputation
6 Guides authored
Clemson, Team 15-3, Benson Spring 2012 Member of Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Members
68 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 27
All Time: 1,049
