Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Feed blade doesn't move properly
Feed blade doesn't move back and forth as it should
Parts need oiling
The blade may just be insufficiently lubricated. To fix this simply apply some oil to [invalid guide link].
No template in place
Open the template retainer plate to check to see if there is a template in place. If there is no template then simply select one that should have come with the device and [invalid guide link].
Template won’t stay in place
The template doesn't seem to always work
Template retainer plate is broken
Upon opening the template container, there should be a metal piece slightly sticking up. If it’s not, try to lift it back up. If it’s missing try placing something such as a piece of cardboard .3cm thick to help keep it in place.
Lock on template retainer plate is broken
There should be a small piece of metal protruding from the bottom. If it’s there, make sure it’s not bent. If it’s not there, try to glue something in its place that's .4cm by .2cm by .1cm.
Can’t adjust the size of the stitching ring
Something is wrong with the size of the buttonholes
The size adjuster isn't moving
The size adjuster lever could be stuck. [invalid guide link] and check to see if there’s something keeping it stuck in place.
Spring on fork arm is broken/missing
There should be a spring that connects to the fork arm. If it’s broken or missing , turning the knob causes the device to go in a line rather than an oval pattern. Try [invalid guide link] the spring.
Knob won’t stay in place
The main knob wobbles around
Knob is not properly screwed in
The knob could simply [invalid guide link]. Try to push down and turn it clockwise until you start hearing a clicking noise. If it’s clicking but still wobbling, there might be another problem.
Screw is stripped
Take out the knob but turning it counterclockwise. If the screw appears to be missing its ridges you can try ordering a replacement for it.
Spring is missing
The knob should have a spring wrapped around the screw. This helps connect the knob to the device. If it is missing, you could try ordering a replacement for it.
Author
with
Michael Sykes
552 Reputation
5 Guides authored
USF Tampa, Team 3-6, Brown Fall 2014 Member of USF Tampa, Team 3-6, Brown Fall 2014
USFT-BROWN-F14S3G6
5 Members
60 Guides authored
1 Comment
This is a good site, but I do not know the terms for parts. Pictures needed!
aledra - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 757
