Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The wheels won't move
No matter how hard you push, you can't get your Literider to move
The wheels might be locked
Before disassembling your Literider, check and make sure that the wheel locks are off. If the wheel locks are on, the Literider's wheels will not rotate. If your Literider's problem isn't so easily solved, read on.
The wheels are broken
If your Literider's wheels are not moving, even with the locks off, the wheels must be replaced.
The fabric is damaged or dirty
The fabric on the stroller is damaged or not in optimal condition.
If the fabric is damaged you will need to replace the fabric.
The fabric is dirty
If the fabric is dirty and needs a cleaning you may refer to our cleaning and replacing guide.
The stroller will not collapse
The frame of the stroller is locked in an open position despite pressing the button on the handle to collapse it.
The button on the handle is broken or is not allowing the handle to twist
If the button or handle is not working properly you may refer to our handle replacement guide.
Author
with
Sohil Bhakta
55 Reputation
0 Guides authored
Cal Poly, Team 11-4, Forte Fall 2015 Member of Cal Poly, Team 11-4, Forte Fall 2015
CPSU-FORTE-F15S11G4
5 Members
36 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,489
