Gigabyte Aorus X7 v2 Troubleshooting
This troubleshooting page is to assist with common problems regarding the Aorus X7 v2.
Feedback loop with mic and audio
While the microphone is on, there is an echo.
Listening to device
Go to microphone properties>listen>remove the checkmark from "Listen to Device".
Volume is Up
You can Lower the system volume by clicking the volume button on the taskbar.
External Microphone
If you are using an external microphone, increase the distance between the laptop and the microphone.
Audio issues with Speakers
Your Aorus device has audio problems due to the speakers.
Cabling issues
Most audio issues related to the speakers are due to cabling issues, the cables may be connected incorrectly or may be of low quality.
Settings
You may be having audio issues due to your settings on your Aorus X7 v2 you can go to settings and troubleshoot the speakers and then switch your settings to the correct ones
Muted Volume
Your audio problems may come from your Aourus device is muted. If your device is muted go to settings and unmute audio or click on the volume button on the taskbar and turn your volume up.
Poor Battery Life
The Aorus has a poor battery life
Too Many things running at once
The reason your battery may be poor is that you have too many apps/tabs/processors running at once you can close them out to increase your battery life.
High Brightness
Having a high brightness can drain your battery if you turn down your brightness it will increase your battery life. You can turn down your brightness using the f2 and f3 keys.
Blue Screen of Death
if the problem is internal, it might be coming from a faulty motherboard.
Power Supply issues
The power supply can eventually burn out or get damaged and it's possible you may have to get a new one.
Application Issues
The Bluescreen of death is sometimes caused by an application crashing or application failure to avoid application failure you can reset your laptop frequently, so the applications aren't running in the background.
Faulty Motherboard
The motherboard may be damaged and might need a replacement. The replacements for the Aorus X7 v2 have been discontinued by the manufacturer. you can still get the parts online here is a resource.
Device is Overheating
If your performance is slow then your device is overheating.
Dust in Fans/Vents
Computers can have a build-up of dust in their fans and vents leading to overheating. To fix this problem use a can of compressed air to blow the dust off carefully.
Charger
Sometimes overheating is caused by the charger if you are not using the original charger, it might be the reason for your device overheating.
Adrian
51 Reputation
0 Guides authored
Gateway, Team 1-4, Pee Fall 2022 Member of Gateway, Team 1-4, Pee Fall 2022
GCC-PEE-F22S1G4
3 Members
60 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 27
All Time: 644
