Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Trouble powering on/off
GPS will not turn on
Make sure the device; cable adapter, is plugged into your vehicle. The light on the adapter will turn on as soon as it is plugged in.
Is your software up to date?
Be sure to update your GPS. Having the latest software update will give the device a higher chance of operating correctly. After downloading Garmin Express to your computer, plug in your device and click on the update tab.
Overheated battery
Your GPS device is not made to be in direct sunlight. If it has been in direct sunlight, place in a shaded area and wait for it to cool down before using.
Battery will not hold a charge
Device will not stay on while in use
Check the fuse in the cable adapter. If that is not the problem, try changing the battery within the device. The GPS will also not hold a charge if it is placed in direct sunlight or in a hot environment.
Unresponsive screen
Does not respond to touch
Be sure the screen in wiped clean from dust. Having a dirty screen will keep the device from sensing your finger movements. If you can hear sound, the motherboard is working and the screen will need to be replaced.
Attempt to perform a master reset
Start with the device off. Press and hold the lower right corner of the screen and turn the device back on at the same time. Answer the questions that follow.
Try recalibrating your device
Start with your device off. Press and hold the upper left corner of the screen and turn the device on at the same time. After powering on, release the screen when “touch dot” appears, and touch the dots as they appear. Calibration will be complete.
No satellite signal
GPS keeps losing connection
If your device has not been used in a long amount of time or has recently been reset or updated, it may take up to 3-5 minutes to acquire satellite signals. Interference with tall buildings also may cause the device to lose satellite signal. You can also try taking the device outside in clear skies.
Navigation voice will not sound
Unable to hear the voice on the GPS
Make sure your device has not been damaged or have come in contact with any liquids. If the device is working and you are having trouble with the GPS voice, you should try resetting the device. If the device still does not sound then you will need to replace the speakers.
Taylor Bratsch
6,174 Reputation
14 Guides authored
2 Comments
gps showing low battery when in car, charges from pc?
dave - Reply Share
have a nuvi 275wt,but flashes on screen logo,and won't go onyo.mass storage! if sd card is inserted it goes past the flashing logo,but still has issues,and no mass storage access,can anyone help?
Neilll33 - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 8,492
