Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
GPS not Powering On/Off
No matter what you do, you can't get your GPS to turn on/off.
Drained/Bad Battery
If your GPS wont turn on, attempt to charge the GPS by connecting it to the AC adapter or your computer using the USB cord. If the battery is still good the GPS will pick up the adapter or the computer will recognize the GPS. If neither happen battery must be replaced.
Power Button no Longer Working
If the GPS is able to turn on after being connected to a charger than it may just be that the power button is no longer intact and power button must be replaced.
Audio Distortion
GPS turns on but unable to hear any audio coming from the GPS.
Blown Speaker
If no audio is coming from the speaker located in the back of the GPS than the speaker may have been damaged if dropped or may have been exposed to excessive water vapor or water. If that is the case the speaker must be replaced.
Speaker is not Loud Enough
Not having enough power may be one of the reasons why the speaker can't produce a good sound.
GPS not Picking up Charger
GPS works but doesn't seem to charge when connected to a charger
Wrong USB Connector
Make sure you have the right charger. Garmin will only work with a Garmin charger. You may have accidentally picked up a blackberry charger or the wrong charger.
Charger itself no onger good
If GPS is not picking up the charger , the charger may no longer be good. Trying using a new or different charger for the GPS.
Mini USB Port Bent/ Loose
If GPS has been dropped USB port could be damaged and could be why the GPS does not pick up the charger. A good way to conclude that the port is damaged is visually look at the port and see if it looks damaged. If by visual it is hard to determine connect the GPS to a USB port charger and then connect it to a computer. If computer recognizes the USB device than the port is fine, but if computer does not recognize the USB device than try to connect another device and see if the computer picks up that device, if computer does pick up other device than the port on the GPS may be damaged.
Microphone Unresponsive
GPS turns on but microphone fails to identify audio
Microphone no longer attached to motherboard
The problem is that the connector for the microphone comes detached from the circuit board. It is possible to fix it by adding new tracks from two resistors to the connector.
Display Unresponsive
GPS turns on but screen is difficult to read and to operate.
Scratched/ Damaged Frame
After dropping GPS the frame gets damaged but touch screen is still operable. The frame can not be repaired, so it should be replaced.
Screen Cracked/ Shattered
If GPS has been dropped and screen shatters or cracks and touch screen no longer works than there is no way to repair a touch screen so best option is to replace screen.
Ricardo Solis
1,058 Reputation
6 Guides authored
USF Tampa, Team 15-2, Remmell Spring 2016 Member of USF Tampa, Team 15-2, Remmell Spring 2016
USFT-REMMELL-S16S15G2
4 Members
72 Guides authored
7 Comments
garmin nuvi 1490 has dots on the outside edges
Charles Schmidt - Reply Share
Our Garmin screen has a dot on lines with the words “Press here.” A finger press results in the dot jumping to another spot on the line—over and over again. NO MAPS!!! Can you help?
pjw00 - Reply Share
That sounds like the game that Garmin installed to make you nuts and therefore buy a new one.
MAX HEADROOM - Reply Share
My Garmin charges sometimes and then states that connection has been lost and that it will close down in so many seconds, then I wiggle the cable and it lights up again. But it’s also done that while I’m charging it on the computer and it did it today with a brand new cable in the car. So I’m assuming it’s the Garmin itself at fault. Any answers for me out there please?
Jo Kinnaird - Reply Share
My garmin nuvi not displaying road maps, only car against a pink background.
barnabasat45 - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 15,134
