Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Potential Problems:
Joystick unresponsive/not working
No input from controller is being received by gamecube
Is not vibrating/rumbling
Buttons are sticking/getting stuck
Joystick Sticking/ Unresponsive
The joystick is stuck in one direction or misaligned. Or the joystick is completely unresponsive
Joystick is stuck in one direction or misaligned
If your joystick controls are going in unwanted directions or moving on its own, there's a good chance your joystick is attached to the motherboard incorrectly or your device is dirty. First, vigorously wiggle the joystick. This may dislodge some dirt or debris and your controller will work correctly again. If that doesn't work, you may need to open up your device, clean and wipe all dirt and dust out of the controller, and properly reattach the joystick to the motherboard.
Controller input not being accepted by system
There is no connection between the controller and the console. The controller is unresponsive
The first thing you should do is turn your gamecube off and back on again. If the problem persists, the second step is to check if another controller works by plugging it in in place of the original. This will determine whether or not it is your controller. If that controller also doesn't work, try a different port. Chances are you will find out if its the port or your controllers. If both controller work in neither of the ports, the problem is with either both controllers (try a 3rd) or your console. If it is the console, consult the GameCube device page. If it is your controller, and not the console, a temporary solution would be to blow into the end of the cord that connects to the GameCube.
Rumble Feature doesn’t work
The controllers rumble feature does not work.
It could simply be that the game doesn’t have a rumble feature so it doesn’t work for this game.
Otherwise it is most likely a bad connection with the motor or that the motor is burned out and the only solution is to replace the motor.
Buttons That Stick
The buttons stick in the downward position when pushed.
First check if the button is dirty underneath. Remove the button and thoroughly clean the underside before reattaching the button and reassembling the controller.
Author
with
Kelsea Weber
21,643 Reputation
32 Guides authored
iFixit, Team S1-G1, Weber Summer 2018 Member of iFixit, Team S1-G1, Weber Summer 2018
FIX-WEBER-SU18S1G1
5 Members
396 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 45
All Time: 3,906
