Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera will not turn on
No matter what you do, the camera will not turn on. The best way to solve the problem is to replace the battery or check if it is facing in the right direction.
Battery needs to be charged
Plug the charger to the camera. Make sure the right power adapter is plugged in. If it is, make sure the light on the adapter is on. If the light is not on, and the adapter is plugged in, the adapter is faulty. Then, consider purchasing a replacement adapter.
Battery placed the wrong way
By opening the battery door, check if the battery is inserted inside correctly by having the three stripes that connects inside on the camera.
Battery is faulty
If the charger is plugged in, and the light on the charger is on, but then the battery is not powering up then the battery is faulty. Replacing the battery is the best solution.
LCD screen will not display image
Dead pixels, scratches, or the LCD screen is broken.
LCD screen is faulty
No matter what you do, the screen will not display anything or respond to any touch gestures. Replacing the LCD screen is the best option.
Camera case is damaged
Lens cover does not slide down to turn the camera on.
Lens cover is faulty
If your camera does not turn on because the lens cover is not sliding up and down properly, it can be replaced by unscrewing the case of it. You need to take out some screws on the left side, right side and bottom part.
Sam Clark
301 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Bhusal Fall 2015 Member of UMass Dartmouth, Team 1-6, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G6
2 Members
36 Guides authored
1 Comment
Card is not initialized comes on the screen, but I took a perfect photo before that.
annawalsh17 - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 34
All Time: 1,951
