Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Lens Malfunctioning or Broken
The lens takes blurry pictures whenever I try to use it
Dirty Lens
Dust, condensation or anything on the surface of the lens can blur the pictures. Try wiping the lens with a clean wipe to help remove anything on the surface.
Uncalibrated Lens
A lens calibrator can help you calibrate a camera's lens. Calibration options will be in the camera software.
Lens Broken
If the above solution does not work, the lens is more than likely broken. If that is the case, you will need to replace it which will require disassembling the camera.
Zoom Button Damage
The zoom does little to nothing when pressed.
Button Wear
Try tapping the buttons to see if they click. If they don’t, check to see if this is caused by either a misaligned button or a broken dome (the button has worn beyond a simple jiggle). If misaligned, try to see if you can click it back into place with gentle nudges.
Button Permanently Cracked or Deformed
If the button appears to be beyond saving, the other option would be replacing. Buttons are not expensive and usually easily accessible once the case is open. This will require partial disassembly of the camera, but no soldering or electrical connections.
Power Button Damage
The camera will not power on when the power button is pressed.
Dislodged Battery
Ensure the battery is securely in the slot and facing the correct direction. Remove it and push it back into the slot.
Battery without Charge
Plug in the micro usb located under the right side panel. Let it charge for 10 - 20 minutes then attempt to power on the device.
Faulty Battery
If you are obtaining no result shown the previous solution, you could attempt to plug in a compatible battery or buy a replacement.
Case Has a Crack or Broken Seal
The camera automatically shuts off when use under the water and water leaks out of the case.
Seal is Broken
If the camera powers off automatically while under water then there is a high chance that there is a failure in the sealing of the camera. Look around to find the area where leakage appear to be most observed. Attempt to open and re-seal the case of the camera.
Case Broken Beyond Repair
If you can not afford another case and your case camera is broken. However, if you can not afford to acquire a new one or want one that can be used universally.
Images Are Distorted/ Optical Aberration
Images appear as if they were going inside or out of the camera display
Settings Error
Turn on the camera and press the menu button to check the settings for taking photos. The white balance may be on the wrong setting, causing inaccurate colors in photos.
Photos Distorted
Use software such as Lightroom and Photoshop to modify and correct the distortions noticed in the pictures.
Flash not working
The camera will take a picture but flash is not visible.
Flash Bulb Burnt Out or Cracked
If the camera is taking pictures but no flash is seen, that means that the flash bulb has burned out and needs to be replaced.
When trying to replace the flash bulb, extra caution must be taken as it is highly dangerous to replace a flash bulb. This is because they typically use a high voltage that has been stored up across a long period of time in order to work. This job may require professional hands if you are not confident in your abilities.
This job will require dismantling the camera as well as acquiring a soldering iron. Most flash bulbs are soldered onto the motherboard of the camera.
Richard
36,260 Reputation
11 Guides authored
1 Comment
My battery compartment cover has broken into bits! I need to buy a new door, can you help me?
Bonnie Brown - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 31
All Time: 1,716
