Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera will not turn on
Even if you press the power button, the camera does not respond.
Drained or Bad Battery
If the your camera won't turn on, the battery may just be dead or faulty, so just replace the battery.
Battery Inserted Backwards
Your camera may not be turning on simply because the battery was inserted backwards. Try replacing the battery.
Dirty Battery Port
It is possible that there is dirt built up at the battery connection site which would prevent the camera from turning on, so just clean out the battery port with a cleaning cloth.
Bad Motherboard
If your camera is not turning on, the problem may be solved by replacing the motherboard.
Flash is not working
When trying to take a photo with flash, the flash won't go off.
Camera not set to flash
You may not have the camera on the proper setting to use the flash for your photo.
Flash bulb is burnt out
The flash may not be working because the bulb needs to be replaced.
Camera will not focus
When trying to take a photo, the camera won't focus the image.
Lens is dirty
If there appears to be some dirt on the lens, clean it with a cleaning cloth.
Lens is cracked or scratched
If you see any damage directly on the lens, you should replace the lens.
Bad Motherboard
If the camera won't focus, you might be able to fix it by replacing the motherboard.
LCD Screen Errors
The LCD screen shows errors when you turn the camera on.
Loose LCD connection on motherboard
There may be a loose connection between the LCD screen and the motherboard. To fix this, check out our LCD connection repair guide.
Bad LCD Screen
The LCD screen may be showing errors because it is faulty and needs replacement. Take a look at our LCD screen replacement guide to get this bad boy back in working order.
Brandon Benavente
704 Reputation
6 Guides authored
USF Tampa, Team 3-6, Sullivan Spring 2016 Member of USF Tampa, Team 3-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G6
4 Members
72 Guides authored
12 Comments
I have a FujiFilm FinePix S1, and my flash will not come on. The screen just says that it is off even when the flash is up to go off. What do I need to do to fix this?
tasluvsu32294 - Reply Share
Sorry I can,t help you , but I have a problem of my own. When switching camera on , the power comes on but screen stays blank as if shutter is jammed closed. The LCD screen comes up with all the menu. On the LCD screen a digital pic of a camera and explanation mark in RED. Any ideas as the camera is only 2 years old and hardly used
David Jack - Reply Share
I have a finePixS. When turned on it says i should turn it off, remove lens cap and turn again. But the lens cap is off already. Help anyone?
Cecil Nundwe - Reply Share
Could this be a mechanic issue (friction) with the zoom lens? That's what I have been suffering for long.
mw120970 - Reply Share
I cannot figure out how to fully extend my fuji s2500 hd camera len
Barbara Redwine - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 48
All Time: 5,878
