Student In Progress
This wiki is being worked on by hardworking students.
Flydigi Apex 2 USB Won't Connect.
The device doesn't seem to connect after plugging in the USB terminal.
Faulty USB Stick or Port
First, check if the USB device is on and not faulty. We can ensure this by checking the device in another port or on another computer.
Software Issues
Restarting your device can help clear any temporary issues. This might also solve some of the software issues.
Low Battery
If the controller has a low battery, the wireless connection can fail. Fully charge the device or connect it directly to the computer with a C-type wire and check if connection is then established.
Wireless Interference or Range Issues
Nearby electronics or metals can interfere with the connection.
Move the controller and the receiver closer together and further from Wi-Fi routers or other wireless-connected devices.
Dirty USB Stick
Dust and dirt can accumulate inside the USB stick. Clean the inside of the USB stick with isopropyl alcohol and let dry until the alcohol is fully evaporated. Then try plugging it back in.
Motherboard Failure
The main board may be damaged, which can prevent the Wi-Fi connection from working. Test the controller using a wired USB connection. If it works while wired but not wirelessly, the receiver or internal module could be faulty.
If the issue persists, you might have to replace the motherboard using "this guide."
Author
with
Luis Padilla
151 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 46
All Time: 46
