Student In Progress
This wiki is being worked on by hardworking students.
Flydigi Apex 2 Bluetooth Won't Connect.
Your Flydigi Apex 2 won’t pair with your phone or tablet, or it keeps disconnecting.
Controller Is Off, Asleep, or Low on Battery
Set the power switch to ON. If the controller is asleep, press Pairing once. If the power light flashes red, plug in the charging cable and wait for the green charging light to turn off.
Controller Is in the Wrong Connection Mode
Hold Pairing + B for three seconds to switch to Bluetooth mode. Open your phone or tablet’s Bluetooth settings and select the controller if it appears. If it doesn’t appear or won’t connect, open Flydigi Game Center and select Setting Management → Connect.
A Previous Pairing Is Blocking the Connection
If the Apex 2 is saved in your phone or tablet’s Bluetooth settings, tap it and select Forget or Unpair. If you previously paired it with another nearby device, turn off Bluetooth on that device. Then repeat step 2 to pair the controller again.
Distance or Interference Is Weakening the Signal
Move the controller within a few feet of your phone or tablet and try again. If it works, get closer to the device and away from walls or Wi-Fi routers.
The Device or Operating System Is Incompatible
Check your device’s manual or support page to see if it supports the Flydigi Apex 2 over Bluetooth. If it doesn’t, check whether a wired connection or the included USB adapter will work with your device.
The Battery or Bluetooth Hardware May Be Faulty
If the controller shuts off as soon as you unplug it after charging, the battery or charging circuit may need service. If it stays on but won’t pair with two compatible devices at close range, contact Flydigi support.
Author
with
Mo Mohammad
101 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 50
All Time: 50
